Any help?
- Registered for: 4 months
Any help?
Apologies if this is the wrong section. I've got a 2015 Amarok 2.0TDI auto with 174,000 km. Recently, the front right wheel started jumping with a rumbling noise as I speed up. VW dealer says the front right wheel bearing is worn, quoting R4000 for two bearings and R2000 for labor. Should I change both front wheel bearings as suggested, or just the worn side? What's the typical lifespan of these bearings, and does changing only one compromise safety? Thanks!
- Neuk
- Treasurer
- Membership No: 806
Re: Any help?
I am not sure where you are based but if possible, contact a VAG Spec Centre outlet for at least a second opinion.
- Registered for: 2 months
- Car Make: Byrdhoulk
Re: Any help?
Have you considered seeking a second opinion from a VAG Spec Centre outlet regarding the front right wheel bearing issue on your 2015 Amarok, especially given the significant cost involved in the VW dealer's quote?
- Membership No: 2033
Re: Any help?
AI ...... is that you?Balakhoulk wrote: ↑Tue Jan 30, 2024 12:24 pm Have you considered seeking a second opinion from a VAG Spec Centre outlet regarding the front right wheel bearing issue on your 2015 Amarok, especially given the significant cost involved in the VW dealer's quote?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
