Hi Guys
Need some help with fault finding, had my car with 3 garages and no one knows what's the issue..
Egr vacuum pipe is on then the car smoke and have no boost...computer say insufficient air flow to EGR.
If I remove the vacuum pipe on the EGR Valve it's not smoking, the boost is there but then the car struggle to start..
I have replaced EGR Valve and the Black Vacuum box thing..
Any ideas ? I'm almost giving up here.
EGR/NO BOOST/VACUUM ISSUES 2007 Audi A3 TDI
- Registered for: 10 months
- aristo92
- Membership No: 3133
Re: EGR/NO BOOST/VACUUM ISSUES 2007 Audi A3 TDI
Where are you based bud?
Sent from my SM-F936B using Tapatalk
Richardsbay currently.
- aristo92
Not sure who refer you to out that side.
Are the vacuum pipes routed correctly? Also make sure the small vac pipe that's going to the airbox is not blocked or kinked.
