Location of fuel sender unit VW Caddy bakkie
gamefroggy7607
Registered for: 1 year 6 months
Post by gamefroggy7607 »
Hi guys. Where is the fuel sender unit located on the caddy bakkie? I filled the tank but the gauge jumps between half and three quarters the whole time.
Car Make: VW, VW, Aprilia
Re: Location of fuel sender unit VW Caddy bakkie
Post by Jetta2 »
Fuel sender unit is inside the fuel tank.
gamefroggy7607
Thanks. Apparently those units are discontinued. Hoping that something is just loose inside lol.
UDC
Membership No: 1041
Post by UDC »
gamefroggy7607 wrote: Tue Jan 03, 2023 11:46 pm Thanks. Apparently those units are discontinued. Hoping that something is just loose inside lol.
Golf1 sender unit will fit there, remove the sender unit from tank and inspect, most likely the float ball came off the arm.
hold sender unit in hand and move the arm and check gauge to test if readings are in sync
