VAG COM / VCDS Register
Chris_FZ
Registered for: 8 years 10 months
Car Model: 2017 Vw Golf mk7.5 R
Membership No: 2065
Re: VAG COM / VCDS Register
Post by Chris_FZ »
Coll012 wrote:Hi guys, anyone with VCP?
Waiting on mine to land.
Not sure when it will be here .
Once I have it ill post that its available
Sent from my SM-G988B using Tapatalk
-Vw Golf mk7.5 R Custom Tune -
- Meth / Eth / Fuel
-Onxy White & Black Trim
-Rolling on 19" Z Performance Flow Forged
-Membership No:2065
Coll012
Registered for: 4 years 7 months
Car Model: A3 8V
Post by Coll012 »
Chris_FZ wrote: Thu Sep 17, 2020 8:22 am
Nice
Nizam90432
Registered for: 8 years 3 months
Car Model: GOLF 7 GTI PP
Post by Nizam90432 »
Hi Guys,
I am in the KZN Durban area, and looking for help with VSDC cable to check my car out and run upgrades on my car.
I have 2015 GOLF 7 GTI PP
rajeev
Post by rajeev »
Hi guys,
i require assistance from somebody in DBN who is quite competent with reprogramming via VCDS.
I need to change from adaptive cruise control (ACC) to just normal cruise control (CSS) on a 2005 A6. From a little bit of research, it seems like a few settings need to be changed.
The radar sensor is messed up, but I can live with normal CCS.
nickk15
Registered for: 3 years 6 months
Post by nickk15 »
Hi All
I have a Autel Maxscan VAG405 code reader. My cable is faulty on the DB 15 side. I would like to replace the plug, however I cannot find a decent (accurate) schematic of the DB15 Pinouts and description - Could anyonne help with this. Maybe someone with a similar unit could ping the cable out and let me know the result.
Thanks in advance
Ameer
Registered for: 6 years 11 months
Car Model: MK1 1.4I
Post by Ameer »
Anybody with VCDS in Cape Town ?
Need my throttle body adapted and faults checked
Ameer
Car Model: MK1 1.4I
Post by Ameer »
Ameer wrote:Anybody with VCDS in Cape Town ?
Require it for a Vw mk1 - AGG mp9 polocup
JaunR
Car Model: 2016 MK7 GTi Performance
Post by JaunR »
Hello All,
Looking for somebody in Gauteng who can help me with some VCDS coding for my 2016, MK7, GTi,
Please PM me.
Chris_FZ
Membership No: 2065
Post by Chris_FZ »
JaunR wrote:Hello All,
Please PM me.
073 754 5203
- Meth / Eth / Fuel
-Membership No:2065
Rourke
Post by Rourke »
hi guys
citi golf airbag spec
I dont have vcds
thought there is a code/sequence like with the service reset ? if there is any ?
There is no error or fault on the airbag , it was unplugged to change the indicator switch
Anyone use a program successfully with a elm327 diagnostic cable on VW cars?
Any1 willing to clear it for me in boksburg or edenvale area?
Thanks for reply guys
imm
Registered for: 10 years 2 months
Post by imm »
Hi
Is anybody who can assist with VCDS in the Krugersdorp/Roodepoort/Randfontein areas?
Shaunak
Registered for: 3 years 4 months
Post by Shaunak »
Hey!
Anyone willing to do a full scan for me in the emmerentia, linden, franklin roosevelt park area jhb? Willing to pay extra for someone to come out to me. My little obd2 reader isn't as effective.
Please PM me. Car is a mk6 gti
Chrisraptor
Registered for: 4 years 3 months
Post by Chrisraptor »
Hi there sorry if I post this in incorrect section . I need advise on wich scan tool will work on my 2001 golf 4 gti 1.8t . I have tried Creamery 619 Autophix c123 Elm 207 . Wil the xtool vag401 work or wich tool will work the best .please what are you guys using. I have a problem with my cars rpm when driving. When you drive and change gears when the clutch is pressed in the rpm does not drop it hangs just there until you leave the clutch again .
tonydea
Registered for: 3 years 1 month
Post by tonydea »
Anyone in the Roodepoort area who can do a VAG COM scan on a Jetta Mk 3 CLi - OBDII. I am having problems with the aircon and I don’t know if it is ECU related.
Tony
Waylynn
Registered for: 9 years 1 month
Car Model: Mk2 Jetta CLI
Post by Waylynn »
Anyone in Johannesburg
That can help with remapping mp9 ecu?
tonydea
Post by tonydea »
Where can I get the necessary diagnostic tools for my 96 Jetta 3 - OBDII and for my wife’s 2017 Polo sedan - CANBUS ?
I saw mention of a 3VIN license, is that what I would need ?
Thanks for your advice.
Belix
Registered for: 14 years
Car Model: Passat B8
Post by Belix »
if you mean VCDS, you can get is from HEx Diagnostics - https://hexdiagnostics.co.za/product/vc ... face-3vin/
fayyth
Post by fayyth »
Hi there guys. Anybody in Cape Town willing to help out with diagnostics? New owner here. :hi:
fayyth
Post by fayyth »
Any suggestions welcome. Just need a point in the right direction. Things like where to start, what are the most important things to prioritize etc. Hence the diagnostics request. excuse the double post.
gordanfreeman50
Registered for: 10 years 11 months
Car Model: Golf 7 1.4 TSi
Membership No: 3055
Post by gordanfreeman50 »
Hi guys, is there anyone in KZN available to help me out with battery coding and start stop deactivation on my 2014 Golf 7 1.4 TSi?
VW wants R5600 for an OEM battery (which is just a sealed flooded battery or enhanced flooded cell at best) and another R1100 for fitment and coding. I would prefer a Varta AGM 646 battery for R3000 but the dealership says that they only code OEM batteries.
I have been trying to do some reading online and it seems with the right cable and software one can code the car by changing the serial of the battery by 1 digit to let it know that it is new. And additionally set it to fleece (AGM) type?
It's not just the cost of the VW battery that is putting me off but the fact that it isn't even an AGM battery in a vehicle fitted with stop/start.
100% Stock 2005 9N Candy White 1.6i 74kW Sold
"Silver Shadow"BMW 320d E90 2005 Sold :cry:
2015 White Golf 7 Comfortline
KaRBoN85
Car Model: MK5 Jetta TDI
Post by KaRBoN85 »
Anyone in CPT Northern Subs to assist with a VAGCOM scan?
JonathanRS
Registered for: 15 years 5 months
Post by JonathanRS »
hi all
I am in JHB east area - Sandringham (next to Edenvale)
I need access to a VCDS cable - i have been using a friends but its not available currently. im planning to rebuild the valve body on my audi 6hp19A gearbox and need to clear the settings and run the adaptions afterwards. the adaptions need to be done at a specific oil temperature range - helps to have the VCDS plugged in while doing it. takes a hour or two to do with specific driving pattern.
I dont want to start this job unless I know I will be able to use the VCDS afterwards. (possible before just to check and clear any fault codes and read clutch pressures).
I there any one in my area who could assist me with this? I have the software loaded - i just need a cable to access . happy to discuss how we do this.
thanks
Jonathan
0825708510 whatsapp or call
ldmlangeni
Registered for: 4 years 4 months
Post by ldmlangeni »
Awe mense. I have a serious problem. My citi golf was at workshop and needed key coding due to immobilizer not recognizing the transponder. So the guys at the workshop ended up taking out my original computer box and inserted their bypass box to start and move the car in and out of the garage. So now, the electrician coded the key and cluster, tested the key and the error was removed but the computer box was not plugged. Cool, then plugged in the bypass box and started the car with no error on dashboard. So after the electrician tested multiple times, it was working just fine. So the workshop guys only realized later that they plugged the wrong box and put in the correct one. Now the immobilizer error is back, so how do I fix this :bang:
ldmlangeni
UG1985
Registered for: 4 years 9 months
Car Model: MK 5 GTi
Post by UG1985 »
Good day gents,
Wanting to know if someone here can help me run logs.
Have my own cable, but laptop gave in on itself... :bang:
Stay in the North of JHB but willing to meet you where ever :driving:
Thanks!
