Engine Mounts and Vibration
Maxx600RR
Car Model: Mk1 caddy
Post by Maxx600RR »
Do you get stronger (softer or harder ) engine mounts for the MK1 ? Just want to see if I can reduce the amount of Engine rock from the motor. At idle the motor rocks quite a bit... not sure if its good or bad but would like to see if I could reduce it some how.
SHAUN
Registered for: 19 years 8 months
Car Model: 2006 335i
Membership No: 1148
Re: Engine Mounts and Vibration
Post by SHAUN »
You get polyurethane bushes that will reduce engine movement, but expect vibrations.
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
Maxx600RR
Post by Maxx600RR »
Hi shaun
thanks for the quick response, do those poly bushes go into the standard engine mounts ? yeah the vibrations are starting to make themselves known now, something behind the dash is vibrating but only at low rpms or idle rpm.
But the engine movement in the bay is quite a bit rougher than with the standard 1.4i motor. Just want to prevent long term damage if I can.
SHAUN
Membership No: 1148
Post by SHAUN »
volkspares sells a complete poly bush kit for the MK1, from engine mounts to suspension bushes etc.
They are alot harder and will reduce engine movement, but cause of this lack of movement, the idling vibration gets sent through the cars body, and the dash rattles will drive you crazy.
I would just replace the front engine mount with a poly mounting, or even better, upgrade the front mount to a polo mounting.
Looks something like this
Maxx600RR
Post by Maxx600RR »
Some thing like this Shaun...
The unique design and material of Superpro has been used to develop an engine steady bush for your MK1 Golf that will substantially reduce the excessive engine flexing found in up-rated cars without passing noise & vibration to the driver. The kit comes with Superpro's standard 60,000 mile/ 3 Year warranty
A polyurethane front motor mount is available for the Mk1 Rabbit, Scirroco and Jetta and is suited for street or competition use. It prevents the engine from rocking back-and-forth during acceleration, thus aiding in getting the power to the ground. Highly recommended for cars with exhaust modifications.
The passenger side mount is a factory mount from the Turbo Diesel. This mount features a harder rubber construction than the original mount found in gas engine models and helps to alleviate engine rocking.
:cool: looks like Im off to Volkspares this weekend. :grin: Thanks for the help Shaun
darren
Post by darren »
Contact me by pm if you still need,
I am about 99% ready to start supplying these in both kit and individual form,
Any hardness
cheers
darren
Mk2 - 2lt 16v turbo / 224hp - 275Nm 0.7bar (@K.A.R)
330d e90 / FRC software
