Location of fuel sender unit VW Caddy bakkie
- Registered for: 1 year 6 months
Hi guys. Where is the fuel sender unit located on the caddy bakkie? I filled the tank but the gauge jumps between half and three quarters the whole time.
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
Re: Location of fuel sender unit VW Caddy bakkie
Fuel sender unit is inside the fuel tank.
Thanks. Apparently those units are discontinued. Hoping that something is just loose inside lol.
- Colonel
- Membership No: 1041
Golf1 sender unit will fit there, remove the sender unit from tank and inspect, most likely the float ball came off the arm.gamefroggy7607 wrote: ↑Tue Jan 03, 2023 11:46 pm Thanks. Apparently those units are discontinued. Hoping that something is just loose inside lol.
hold sender unit in hand and move the arm and check gauge to test if readings are in sync
