2015 1.2 Tsi engine misfire
- Registered for: 6 months
A month ago my car broke one of its cambelt pulleys which in turn bent some exhaust valves and also my oil pump. I had the pulley, oil pump replaced (goldwagen parts) and also sent the head for engineering to replace the valves. The car basically had a complete service but driving at low speeds, below 80km, the car would jerk. At high speeds it runs fine. When scanned it shows fuel pressure sender is malfunction which I replaced. It also shows misfire on nr 1, 2 and 4 cylinders. We tested another car's injectors and coil packs on my car but with no changes. The head was sent to engineering again to recheck valves but it came back okay. The car still misfires though. Could it be the Non-OEM cambelt pulley thats acting up? Ive spent about 30k on the job and dont know what next
- kingr
- Car Make: VW, Mini, Slowyota
- Car Model: Mk1 2 Door, Hilux D/C
- Membership No: 3337
Re: 2015 1.2 Tsi engine misfire
I doubt the cambelt is an issue.
Does the car struggle to start when cold?
Where were the pistons inspected and fine? If the valves are bent, indeed they hit piston crowns.
It sounds like there's an issue with the timing or electrical wiring on the side of the coils / fuel.
Kurt #3337
- 10" Mx5 NC2 (main daily)
- mk2-phreak
Compression in spec post rebuild?
- Registered for: 4 months
I am sitting with the exact same problem. Took my car for a service to replace spark plugs as a start. While my vehicle was there coils and leads were checked. A pressure check was done and it was found that cylinders were not holding pressure. Upon speaking to a VW mechanic it was noted that there is a lot of carbon build up in the manifold and around the valves either causing the valves to stick or to not seat properly. I still have to decide how or where i am going to get the head pulled and engineered. I am interested to see the feedback on the previous question regarding the compression test?
