Cool. So I might do it one day. Little bit of fabrication but this is simple. Jusyt a rack....BlueBlob wrote:Yep, that's the main thing.panic-mechanic wrote:The MAIN thing you need is the rack. The rest I suppose you can adapt.
There are going to be loads of little fiddly things though, like a shorter clutch cable for one. That you'll also have to import, or get made.
Conversion from Right hand drive to Left hand drive
Re: Conversion from Right hand drive to Left hand drive
'07 Ford Bantam
'11 Ford Bantam
WESBANK Modıfıed mk1 replıca
SOLD
'07 Audi A4 B7 1.8T
'06 Polo 1.9tdi 96kw
'07 Audi A3 2.0FSI
'97 VW Citi Chico 2.0i
'71 Leyland Mini 1000 Stationwagen
'84 Ford Sierra XR6
'96 VW Citi Chico 2.0
'85 BMW 518i
'09 VW Citi GTS
'86 VW Citi Sport 1800
'85 BMW 318ı e30
'89 Toyota Corolla 1.6 GL 16V
'82 Alfa Romeo Alfetta 2000l
'85 Alfa Romeo 159i GoldLeaf
'84 VW MK1 GT
'07 Ford Bantam
'11 Ford Bantam
SOLD
'07 Audi A4 B7 1.8T
'07 Audi A3 2.0FSI
'84 Ford Sierra XR6
'85 BMW 518i
'09 VW Citi GTS
'85 BMW 318ı e30
'84 VW MK1 GT
Looks like mabye this rhd rack could also work. From just briefly looking as one of my spares, you cut all the gear linkage bracket off, flip rack around and we'll em back on. Then just a bit of a mod with the one mount to round the square side and square the round saide so the mount will fit correctly and wala...
'07 Ford Bantam
'11 Ford Bantam
SOLD
'07 Audi A4 B7 1.8T
'07 Audi A3 2.0FSI
'84 Ford Sierra XR6
'85 BMW 518i
'09 VW Citi GTS
'85 BMW 318ı e30
'84 VW MK1 GT
'07 Ford Bantam
'11 Ford Bantam
SOLD
'07 Audi A4 B7 1.8T
'07 Audi A3 2.0FSI
'84 Ford Sierra XR6
'85 BMW 518i
'09 VW Citi GTS
'85 BMW 318ı e30
'84 VW MK1 GT
- Registered for: 22 years 1 month
And if I follow what you are saying correctly then that will also very neatly reverse the direction the wheels turn. So when you twirl the wheel to the right the car will turn left. THAT Should take a bit of getting used to.
- infiltrator
+1panic-mechanic wrote:And if I follow what you are saying correctly then that will also very neatly reverse the direction the wheels turn. So when you twirl the wheel to the right the car will turn left.
current rides:
81 Mk1 GLS
05 Mk5 GTI
81 Mk1 GLS
05 Mk5 GTI
I had this thaught...would need a bit of modifying....hmm. Easyer to import.panic-mechanic wrote:And if I follow what you are saying correctly then that will also very neatly reverse the direction the wheels turn. So when you twirl the wheel to the right the car will turn left. THAT Should take a bit of getting used to.
'07 Ford Bantam
'11 Ford Bantam
SOLD
'07 Audi A4 B7 1.8T
'07 Audi A3 2.0FSI
'84 Ford Sierra XR6
'85 BMW 518i
'09 VW Citi GTS
'85 BMW 318ı e30
'84 VW MK1 GT
'07 Ford Bantam
'11 Ford Bantam
SOLD
'07 Audi A4 B7 1.8T
'07 Audi A3 2.0FSI
'84 Ford Sierra XR6
'85 BMW 518i
'09 VW Citi GTS
'85 BMW 318ı e30
'84 VW MK1 GT
- Wheel Whore
My bud hooked me up with a LHD pedal cluster.
The following will be needed.
LHD steering rack
LHD brake booster
LHD steering column
new clutch cable
wiring might be an issue
apparently there is a guy who specialises in this conversions and I believe a MK1 is easy to do this on
and now for the good news,all these parts can be ordered from VW SA at around double the price of RHD parts, the clutch cable cost about R 300.
LHD steering rack
LHD brake booster
LHD steering column
new clutch cable
Price on a rack?Surge23 wrote:My bud hooked me up with a LHD pedal cluster.
LHD steering rack
LHD brake booster
LHD steering column
new clutch cable
'07 Ford Bantam
'11 Ford Bantam
SOLD
'07 Audi A4 B7 1.8T
'07 Audi A3 2.0FSI
'84 Ford Sierra XR6
'85 BMW 518i
'09 VW Citi GTS
'85 BMW 318ı e30
'84 VW MK1 GT
'07 Ford Bantam
'11 Ford Bantam
SOLD
'07 Audi A4 B7 1.8T
'07 Audi A3 2.0FSI
'84 Ford Sierra XR6
'85 BMW 518i
'09 VW Citi GTS
'85 BMW 318ı e30
'84 VW MK1 GT
On the clutch cable,just use the newer velo clutch cable that's mutch shorter than a normal mk1 so wil work,and the pedal box should be the same and the booster braket then bolts just directly too the brake pedal with 2 bolts,just cut the not needed bits of,the wiring all run from the fuse box so all the wires wil now be too long , the steering rack should also be the same,u just need the lhd steering rack,and to drill a sh@t load of holes in the firewall.
Golf 2l16vT 320kw 520nm
1/4mile @ 12.2 kilarney 2011
800m @ 233km/h
- Wheel Whore
Thanks bro
My bud says the LHD pedal cluster is different, because he had to orderone for his LHD cabrio.
Not sure of the price of the steering rack, but I will go check up at VW Mooi street next week
