White Smoke from Exhaust
- necrotone
Hi Guys,
This morning after driving for +-20 mins, I noticed white smoke coming out of the exhaust while I was letting the car idle before turning it off.
It wasn't super thick, but it smelt like burnt plastic.
I turned the car off for about 5 minutes and then back on - it stopped immediately. very strange.
Anyone got any ideas?
Is it something to be worried about?
2009 Renault Megane F1 R26
EX 2008 Polo GTI (Stolen 12/07/2009 Glenvista)
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
- necrotone
Re: White Smoke from Exhaust
Yeah, I'm pretty sure it wasn't steam - was a little bit thicker than that and it smelt like burnt plastic.Sinbad wrote:Sure it wasn't steam?
- Membership No: 1106
Could possibly be the turbo.
Scirocco
13.5 Dragwars Tarlton 2011
Golf V Gti
14.1 Dragwars Tarlton 2010
ex Golf IV 132kw
14.8 @157kph Tarlton 2007
- Post Whore
- Car Model: boat
- Membership No: 1133
- necrotone
Nope, I actually took the car for a drive earlier and there was no smoke at all.dood786 wrote:Any weird sounds from the engine bay where the turbo is?
Something must have been stuck on the zorst and started to burn. (hopefully)
The only proper check I can do is when I drive home from work.
- rodga
- Nazi Spelling Master
- Car Model: MKVI GTI
- Membership No: 1323
check your oil level
might be overfilled
might be overfilled
rodga's ride
'09 Generic XOR 125 - matte black - Daily Driver
rodga's ride
- necrotone
oil level is normal too... after the long drive home, there was no smoke at all.
false alarm.. thank god!!!
- rodga
cool
let us no if it happens again
rodga's ride
rodga's ride
- necrotone
car did it again last night.. WTF
Seems to happen when the radiator fan kicks in.
There are no funny sounds or loss in performance, so I'm probably just being pedantic.
- Sinbad
- Post Whore
Could be a blown headgasket, if it only happens when the coolant is hot enough to kick in the radiator fan...? Speculating... Car losing water at all?
Also, brake fluid burns white. Could be a leaking master cylinder/booster causing some fluid to get into the intake?
- necrotone
Nope, no water loss at all.Sinbad wrote:Could be a blown headgasket, if it only happens when the coolant is hot enough to kick in the radiator fan...? Speculating... Car losing water at all?
Would VAG-COM throw any errors if there were such problems?
- Sinbad
- Post Whore
Doubtful...necrotone wrote:Nope, no water loss at all.Sinbad wrote:Could be a blown headgasket, if it only happens when the coolant is hot enough to kick in the radiator fan...? Speculating... Car losing water at all?
You'd need to keep a careful eye on fluid levels and oil colour/consistency
- necrotone
I will indeed do that.
strange thing is, it doesn't happen all the time. it happened last night and then 2 day prior to that.
What color shouldn't the oil be?
- Sinbad
- Post Whore
White/milky/creamy. Indicates emulsified water in it...necrotone wrote:I will indeed do that.
- necrotone
Cool, I'll stop off at a garage and check when I'm on my way home. - thanks for the help dude
- Dark Artz
- Car Make: SEAT
- Car Model: Ibiza CUPRA
Let's hope that we can duplicate this tomorrow when you stop by...
hi, mine did that as well a time ago. after a service at vw. seemed they used the wrong oil. they used a 5w40 fully synthetic oil, but when the engine is very hot after boosting alot it starts smoking at idling, the oil goes throug the turbo's seals into the exhaust, making the white smoke. then they changed the oil to shell 10w40 fully synthetic oil, and the problem was solved.
good luck
good luck
POLO GTI 17" IMPORTED RIMS, 63MM DE CATTED EXHAUST,KN FILTER,CUSTOM BONNET
116KW ON WHEELS
EX 2007 POLO CLASSIC 1.6 COMF
2004 POLO CLASSIC 1.6
CTI 1.8 276/288 CAM, PULLY, BRANCH,FLOWED HEAD 100 KW
E MAIL : WERNER.SMIT@KIOLTD.COM
116KW ON WHEELS
- Dark Artz
- Car Make: SEAT
Wicked seems to have had the exact same problem...
guys i had the same problem this morning!!! it is was fine when i left home but i have put oil in at the Engen Garage the other evening. maybe i should start there by do a oil change??
98 vr6 golf with sunroof
94 golf CTI
50 mm s/s powerflow exhaust
king dragon flat bed filter
audi throttle body
17inch tsw apex
89 325i e30
94 golf CTI
audi throttle body
17inch tsw apex
89 325i e30
- Wheel Whore
I had this exact prob on my VR6 Turbo.
Almost paid 2k to do seals on my turbo . It turned out to be my breather pipe!!
The oil catch tank was clogged hence the breather pipe blocked. It stopped the white smoke immediately.
Mine also only happened on idle.
- Dark Artz
- Car Make: SEAT
Necro's PCV pipes are caked with oil...I suspect the PCV system is causing it...Uncle Morne will provide expert diagnosis soon...
- necrotone
I've booked the cab in for Thursday.
We shall see what the experts have to say
