2009 Yaris sump gasket
I ave a 2009 yaris sedan 1.3.
The sump is leaking where the gasket go's.
what i need to know is , is there a sump gasket on the market and where should i get 1 ?
i spoke to my spare shop and they say there is no gasket and silicone is my best bet.
I am sure that originally it would have come with a gasket so there must be?
Cheers
Cheers
- Neuk
- Treasurer
- Membership No: 806
Re: 2009 Yaris sump gasket
Have you tried a Toyota dealer? I remember finding a Toyota spares place a few years ago for my ex-wife's Yaris, I'll try find out what it was called and where they are based.
- Rascal69
- Registered for: 16 years
- Car Model: MK1
- Membership No: 1490
Toyota should have the gasket... if you want another brand like Elring or Vestor Reinz, you can check with Midas and ask them to order you one.
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
thanks guys
I was thinking of asking the dealer or goldwagon but just wanted to know if the sump has a gasket ?
also wanted to findout where u guys have found it?
is it beter to put the gasket than to put just the gasket maker (Silicone)
regards
regards
- Pynoxim
Usually toyotas don't have a sump gasket, they just use their own in house sealant called FIPG, which is the same as Hondabond
so should i try and get a gasket ?
already found out that goldwagon dont have
- Neuk
- Treasurer
I can't find it but either a Toyota dealership should have what you need.Neuk wrote:Have you tried a Toyota dealer? I remember finding a Toyota spares place a few years ago for my ex-wife's Yaris, I'll try find out what it was called and where they are based.
- Car Model: MK5 GTI DSG BWA
- Membership No: 1156
Have you tried Gemini parts? They import Toyota parts
Contact Gemini Parts
Tel: 011 334 1417
Direct Sales Tel: 011 025 8224
076 700 6241
071 107 2286
079 349 9160
Fax: 011 334 0069
Email: sales@geminiparts.co.za
Physical Address: 16 Kruis Street
Marshalltown
Johannesburg
Gauteng
Tel: 011 334 1417
076 700 6241
071 107 2286
079 349 9160
Fax: 011 334 0069
Marshalltown
Johannesburg
Gauteng
2012 Dec Mk6 GTI CW DSG - REVO Stage 1
Ex 2008 White Golf 5 Gti DSG REVO3 K04 - Weekend Toy
Regards
Hoosen
072 135 7861
Regards
Hoosen
072 135 7861
thanks guys
will contact jhb as last resort but will try locally first
thanks again guys
if i dont get it than gasket maker it will be
regards
thanks again guys
regards
guys so toyota has confirmed this car does not use a sump gasket but the sealer.
I also went to a engine spares and according to the payen book it also confirms a gasket maker or sealer.(The payen book shows if it needs a gasket and the book shows silicone sealer) that book is detailed nicely.
So i dought that i will get any sump gasket for this car.
Thanks alot.
Thanks alot.
- Rascal69
- Car Model: MK1
oh no gasket, so If thats the case then you can try Elring High Heat Gasket maker...
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
JDoe wrote:oh no gasket, so If thats the case then you can try Elring High Heat Gasket maker...
will i find this in the local spares like midas?
I have the more expensive 1 that was purchased at midas will recheck on the name but was over R120 not the cheap 1s you find for R40.00 odd rand
Cheers
- Rascal69
- Car Model: MK1
should be ok if its High Heat... i was just mentioning that specific elring one coz i used it when i rebuilt my M Diff and its holding up well..
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
thanks buddy will have to check and get it done
cheers
cheers
Loctite 5699 grey RTV sealant.
Can confirm that very few Toyota's from about 2000 MY on have a physical gasket. 99% use sealant.
That said don't blame the sump for your oil leak unless you have washed the engine and confirmed the source of oil. In my experience with Toyota engines it's very rare that the sump leaks unless it has been bumped or cracked. Oil leaks further up can make a big mess under the car. Check the dipstick o-ring while you are at it. Oh and install a new oil filter with the clean oil.
thanks missioner
Well i have taken the car to toyota for service and even they pointed out that the sump is leaking current quote to reseal R1700.00 from toyota.
It is very little oil very little i have since drove 5000kms and the dipstick indicates almost no oil loss even though you can see the oil dirt under the car by the sump. not on the ground .
I have started parking the car on conrete at home from 1st january so now i actually see some small oil spots on the concrete.
I still check and the oil is still full as indicated on the dipstick
I just think its beter i do it now before all oil runs out.
Also the rest of the engine is dry its just the sump (Engine has no oil leaks whatsoever not even the sweating marks. its all alluminium no dirt
thanks again guys
thanks again guys
HI Guys
what is the correct grade oil that the 2009 1.3 2nz-fe motor uses?
I had it serviced at toyota so i dont know the grade.
i just need to top it up a little so 1 500ml should be enough.
thanks
thanks
