Need some advice on a seat ibiza 20l sport
dfu
Registered for: 6 years 3 months
Post by dfu »
Hi guys .hope everyone's good .i have a seat ibiza it's a 20l 8v X flow . at the moment the motor is been taken apart and i am planning on boosting it .need advice on the parts needed ?
Going with a T28/T3.
Wat pistons should I use to drop compression. Or is it possible to resize the conrod if yes by how much ?
Injector size.and Wat injector can I buy to fit in the original fuel rail.
The car is been used every day I want it done reliable ?
Ecu: standard computer box with a dastec and a module. (injection module )
Sent from my GT-I8200 using Tapatalk
hubbly_bubbly
Registered for: 13 years 10 months
Car Model: Touran GTD
Membership No: 1793
Re: Need some advice on a seat ibiza 20l sport
Post by hubbly_bubbly »
Interesting project.
I cannot comment on the required parts though, goodluck!
What power are you hoping to make? Reliable and aftermarket turbo dont go together necessarily. What budget have you set? I would recommend it being a better idea to sell the 2.0 and buy an Ibiza Cupra 1.8T. At least then the rest of the chassis is built for the power (i.e. brakes, suspension, wheels etc)
Candy White 2007 Touran 1.9TDI Trendline
dfu
Post by dfu »
hubbly_bubbly wrote:Interesting project.
I have around 30k .With the 1.8T would I still use the same stock computer box and looms or would I have to go aftermarket engine management?
MarshallGTi
Car Model: Ibiza 1.9TDi FR
Membership No: 1665
Post by MarshallGTi »
I dont see 30k being enough for a turbo conversion and the necessary suspension and brake upgrades, but if you're set on it scavenge as much as you can off a scrapped 1.8T (A3/Polo GTi/Cupra/Mk4)
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
dfu
Post by dfu »
MarshallGTi wrote:I dont see 30k being enough for a turbo conversion and the necessary suspension and brake upgrades, but if you're set on it scavenge as much as you can off a scrapped 1.8T (A3/Polo GTi/Cupra/Mk4)
I'm sure the stock suspension and brakes should be Fine.as it's the same as a golf 5
I'm not looking for more then a bar of boost.
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
I would rather find a decent Ibiza Cupra.
No, it's the same a MkIV/MkIVF Polo.
dfu
Post by dfu »
Neuk wrote:I would rather find a decent Ibiza Cupra.
Oh kwl .so would put changing the motor .Wat should I drop the compression to ? And what injectors will I need
dfu
Post by dfu »
Sorry I ment with out changing the motor .
dfu
Post by dfu »
dfu wrote:
dfu wrote:I'm sure the stock suspension and brakes should be Fine.as it's the same as a golf 5
y can't I get the car boosted for 30k
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
I have never done it but others here will be able to advise.
DazzG_177
Registered for: 12 years 6 months
Car Make: SEAT
Car Model: Leon Cupra
Post by DazzG_177 »
my eyes
hubbly_bubbly
Membership No: 1793
I think the summary of advice would be to fix the 2.0l motor as is, put it back in the car and sell the whole car.
Then take the money from the car sale and extra R30k and buy an entire Ibiza Cupra.
eg
https://www.gumtree.co.za/a-cars-bakkie ... 1037894809
For our fuel you want about 8.5:1 to use 95 octane and 1 bar on that motor. Best is to bring the correct forged pistons in.
Graham savage that owns goldwagen CBD built a golf 4 with the same motor turbo. We ran it on a perfect power xms.
This piggyback plus turbo module thing never works for me but some people make it work. R30k os about half the budget it will actually cost you in the end.
dfu
Post by dfu »
panic-mechanic wrote:For our fuel you want about 8.5:1 to use 95 octane and 1 bar on that motor. Best is to bring the correct forged pistons in.
Thanks alot .Wat injectors should I use
It really depends on the end power you aim for. And if you use the stock management already upping the injector size is an issue becuase for a start you have to remap the entire stock map for that.
So if it was me 440cc plus aftermarket.
Tman21
Car Model: BosPolo
Membership No: 3247
Post by Tman21 »
What about just dropping a 20VT AEG/AUG (i Think)
Motors are less than 30K and a solid base to start with. Add dictator, 440cc injectors, some plumbing and perhaps a bigger turbo and you could do it for less than 50K but at least you can do it step by step?
Success: When hard work meets opportunity :-)
#TMAN21
Tman21
Car Model: BosPolo
Membership No: 3247
Post by Tman21 »
Like so: http://www.vwclub.co.za/forum/viewtopic ... 0&t=207848
Then you might have some change after fitting this and do the upgrades one at a time or buy all the hardware bit by bit and install in the end.
#TMAN21
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
Why spend all the time, money and effort on this when you can just buy a Cupra?
billionairebum
Car Model: Sportline
Membership No: 3194
Post by billionairebum »
Buy a Cupra or spend double and make an awesome build thread.
Supervan II
Registered for: 18 years 8 months
Car Make: SEAT
Post by Supervan II »
Neuk wrote:Why spend all the time, money and effort on this when you can just buy a Cupra?
The only reason anyone would want to do this would be for the 4 doors vs the Cupra's two.
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
Then I would rather buy a 9n3 Polo GTi if I wanted four doors that much, which I never have.
dfu
Post by dfu »
The car that we doing the setup on is a security response car .We just want a Lil more power out of it .even if it's boost till 0.5 bar. The car is not going to go on a track or racing other cars . .that's y I asked .to boost that motor at 0.5 bar .Wat will I require. .Size injector
.is it fyn to use a t28/t3
.or is fyn to put a double head gasket, or use just use 1 gasket. ...
We do not want to sell the car .
amstel18
Car Model: Tiguan Allspace
Post by amstel18 »
Last thing I would want is to have a security team with unreliable vehicles.
Don't build what you can buy. Especially if its a primary car. Naweekrondfokkar is another story
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
