Dicktator STD assist needed
PapaJo
Registered for: 14 years
Car Make: VW's
Re: Dicktator STD assist needed
Post by PapaJo »
Nice power power after panic’s tune. Well done!!
Now you need to update and show on your thread.
Zuna
Registered for: 15 years 4 months
Car Make: volkswagen
Car Model: MK1 golf GT
Post by Zuna »
after visiting panic place
I'm happy to say I'm almost ready to hit the road
PapaJo
Car Make: VW's
Post by PapaJo »
Don’t stop now. Finish remaining work and post some pictures.
Erens
Registered for: 4 years 6 months
Post by Erens »
Hi having problems with my dictator any one that can help
PapaJo
Car Make: VW's
Post by PapaJo »
Erens wrote: Wed Sep 25, 2019 7:27 pm Hi having problems with my dictator any one that can help
Introduce yourself and then we can assist.
Where are you based?
What’s your issues you have?
Which Dicktator system? Std or 60-2?
Kurt schwartz
Registered for: 4 years 7 months
Car Model: Mk1 caddy
Post by Kurt schwartz »
Hi guys. I really don't mean to jump in here like this but I have no idea how to start a new thread. I have a mk1 vw caddy 1.8 8v that I have converted to fuel injection using a dictator. And I have had her starting up but the revs just climb. Only wire I couldn't figure out if it's right or not is pin 1 on the throttle body. Currently have the red yellow that runs with injectors in there. Could that be the cause?
PapaJo
Car Make: VW's
Post by PapaJo »
Kurt schwartz wrote: Tue Feb 18, 2020 10:23 pm Hi guys. I really don't mean to jump in here like this but I have no idea how to start a new thread. I have a mk1 vw caddy 1.8 8v that I have converted to fuel injection using a dictator. And I have had her starting up but the revs just climb. Only wire I couldn't figure out if it's right or not is pin 1 on the throttle body. Currently have the red yellow that runs with injectors in there. Could that be the cause?
Red yellow wire is switched 12v from ecu. Idle control should be a blue wire from pin 18 ( negative switching).
Explain which wires are connected where to be able to assist.
Kurt schwartz
Pin 1 - red yellow running with injectors
Pin 2 - blue (idle control negative)
Sent from my ELE-L09 using Tapatalk
Kurt schwartz
Everything on motor is standard besides the branch and 50mm free flow
PapaJo
Car Make: VW's
Post by PapaJo »
I take it the pun1 and 2 mentioned is on the idle control motor. Is this a mp9 tb?
Kurt schwartz
PapaJo wrote:I take it the pun1 and 2 mentioned is on the idle control motor. Is this a mp9 tb?
Yes it's a mp9 tb
Kurt schwartz
Yes my pin 1 on tb is connected to pin 17
And pin 2 on tb is connected to pin 18
Is it correct?
PapaJo
Car Make: VW's
Post by PapaJo »
Kurt schwartz wrote: Thu Feb 20, 2020 7:22 pm
Is it correct?
Those are the correct pins on Dicktator.
Krio
Car Make: Vw and honda
Car Model: Mk1 2.0 throtts
Post by Krio »
Hi guys I'm krio
I have a 2.0l 8v. With Toyota 20v throttles.
Been doing all wiring myself. I'm stuck with the idle control... Pin 18. What do I do with that pin?
:geek:
PapaJo
Car Make: VW's
Post by PapaJo »
Krio wrote: Thu May 07, 2020 8:22 pm Hi guys I'm krio
Hi Krio,
Start your own post for more exposure and responses.
To answer your question:
For ITB's you don't use pin 18 for idle control as you cannot connect an idle control valve (ISV) to the intake. All you do is sync the ITB's up on manifold while manifold is not on motor to ensure all are fully closed. Once that is confirmed use the adjustment screw on the casing and adjust so that all 4 ITB's are open the same gap amount.
Krio
Post by Krio »
Thank you so much for the help. Much appreciated.
Sent from my LYA-L09 using Tapatalk
:geek:
PapaJo
Car Make: VW's
Post by PapaJo »
Krio wrote: Fri May 08, 2020 11:36 pm Thank you so much for the help. Much appreciated.
You're welcome, Krio.
AyaThatGuy
Car Model: MK1 Golf
Post by AyaThatGuy »
Bump for updates
PapaJo
Car Make: VW's
Post by PapaJo »
AyaThatGuy wrote: Thu May 14, 2020 12:23 am Bump for updates
Double Bump!!!
When are you showing the new additions, Zuna???
Kurtley Beukes
Registered for: 6 years 9 months
Post by Kurtley Beukes »
Hi Guys im also struggling with my 16v running STD dicktator with Kr dizzy it has spark timing is set compression checked fuel pressure checked but it fails to start amy tips..could it be the dizzy?
PapaJo
Car Make: VW's
Post by PapaJo »
Kurtley Beukes wrote: Fri Feb 05, 2021 7:11 pm Hi Guys im also struggling with my 16v running STD dicktator with Kr dizzy it has spark timing is set compression checked fuel pressure checked but it fails to start amy tips..could it be the dizzy?
Confirm the following:
1. rpm reading on ecu data page. Should be above 250rpm.
2. Settings selected for ignition trigger, timing map and fuel map pictures. Post a picture of your trigger selection and timing and fuel map pages.
3. What is the trigger angle and dwell time set at on the mainpage? Picture of that page.
