Cigarette lighter FUSE [NOOBIE]
Posted: Thu Jul 12, 2012 9:17 am
by zedman1
Hi guys. Need help identifying which fuse is the cigarette lighter. Is it the one that looks messed up?
Is it in the right place cz I took it out and forgot where it goes.
Re: Cigarette lighter FUSE [NOOBIE]
Posted: Thu Jul 12, 2012 9:19 am
by ScottiesKJ
The cover you took off should show you the lay out of that. its all numbered. unless the cover is missing
Posted: Thu Jul 12, 2012 9:25 am
by Crawler
cover has a card in it
your book will also have all of them in
Posted: Thu Jul 12, 2012 9:44 am
by golfsmith
Not all the VW's has fuse layouts or the owners manual not even my 6r Gti have it,had to visit dealer and print it out from there ElsaWin program they have for your car vin-number.
Posted: Thu Jul 12, 2012 10:01 am
by AlexTDi
Melted one will definitely need replacing,
Go ask VW for a print out relating to your VIN number as Golfsmith suggested.
I've seen mine and a friends card on an 08 Polo 1.4 and they are totally different.
Posted: Thu Jul 12, 2012 10:30 am
by zedman1
Thanx guys! Cant find any fuse layout in the manual.
See below. this was on the panel that I took off. It doesn't show the cigarette number.
Posted: Thu Jul 12, 2012 10:42 am
by AlexTDi
BINGO! The Fuse Card
Take the card out and check on the back, It has the second half of your fuse box.
Can’t remember what the picture for the lighter is but I’m pretty sure it's easily noticeable when you do find it.
I replaced my lighter fuse in 2009 so kind of hard remembering which one.
Posted: Thu Jul 12, 2012 10:43 am
by mika1803
The card is double sided, did u check the other side?
Check all the fuses with a test light
Posted: Thu Jul 12, 2012 10:45 am
by AlexTDi
Fuse 41? Smoking pole type of pic?
Posted: Thu Jul 12, 2012 11:14 am
by zedman1
Didn't check behind the card. Its fuse #49. You guys rock!! Thanx!!!
BUT #49 is not numbered.
Will use a test light.
Awesome forum!! Thanx again.
Posted: Thu Jul 12, 2012 11:17 am
by AlexTDi
cool bud glad its sorted
