Spark plugs for 2L ADY?
Benitovw
Car Model: CITI ADY
Post by Benitovw » Mon Jan 09, 2012 2:35 pm
Okay most people tell me to get BPR7ESZ an a few people sayBPR6ES.
I'm not sure which to get now, keep in mind I have a cam,head job etc.
I don't know if makes any differents if the motor is standard or modded.
What are the rest of you guys using that have the 2l 8v motors?
Any input would help.
Thanx alot
CITI 2L 8V
Reegz
Car Model: MK VI Golf GTi Edition 35
Membership No: 1400
Re: Spark plugs for 2L ADY?
Post by Reegz » Mon Jan 09, 2012 9:31 pm
go with what panic-mechanic said in your previous thread.
** Current Rides **
<-- 2012 MK VI Golf GTi Edition 35
<-- 2012 Touran 2.0 Tdi
** Previous Rides **
--> Sold | 2012 Jetta 6 1.4TSi
--> Sold | 02 Polo Playa | --2.0 ADY--
--> Sold | 04 Ducati Monster M400
--> Sold | 08 CBR 600 RR
--> Gone to Heaven | 06 CBR 600 RR Movistar
--> Sold | 96 Mk I CTi
Fran
Membership No: 1306
Post by Fran » Mon Jan 09, 2012 10:18 pm
Hi :hi:
Which one are you currently using?
Carburetted citi golfs uses BP6ES (warmer plug)
Fuel injected ones run the BP7ES (colder plug)
Been running BP6ES since Sarel from 8 valve performance did the conversion from 1.6i to 2E (the golf in my signature). Only changed to BP7ES three weeks ago. Had no issues previously.
Hope this helps.
2000 Vw Citi ABF 2.1 16v, tdi crank, 84mm pistons, Dicktator - 115.5kW & 202 Nm at the wheels
Benitovw
Car Model: CITI ADY
Post by Benitovw » Mon Jan 09, 2012 10:25 pm
@ Fran why did you change?
CITI 2L 8V
Fran
Membership No: 1306
Post by Fran » Tue Jan 10, 2012 8:07 am
Hi, only changed as they were they correct heat range for MP9 citi's, they slightly cooler than the BP6ES's.
Which one you going for?
Benitovw
Car Model: CITI ADY
Post by Benitovw » Tue Jan 10, 2012 8:27 am
So I should go for bpr7es? I'm mp9 aswell with a polocup ecu.
CITI 2L 8V
Fran
Membership No: 1306
Post by Fran » Tue Jan 10, 2012 8:48 am
The 'R' in BPR7ES refers to 'resistor', not sure what the effect of that is.
Which version have you used up to now and why you changing?
:driving:
Benitovw
Car Model: CITI ADY
Post by Benitovw » Tue Jan 10, 2012 9:09 am
@Fran I'm using bp6es at the moment.
I thought bpr7es is the same as bp7es, my bad.
I'll try bp7es or even stick with bp6es.
I just want to get the proper plug for the motor.
How's the bosch plugs?
You using ngk right?
CITI 2L 8V
Fran
Membership No: 1306
Post by Fran » Tue Jan 10, 2012 9:57 am
The difference that 'R' makes we do not know. Could have something to do with radio reception/interference.
Yes, using NGK. Bosch and Champion seems to be less popular then a few years ago.
Zubair
Car Model: MK1
Post by Zubair » Tue Jan 10, 2012 10:13 am
NGK BP7ES I've used on all my modified and turbo 8V's.
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
Post by panic-mechanic » Tue Jan 10, 2012 3:31 pm
The r is to stop that tick tick you get on the radio yes. If you have good leads with resistors then it doesn't matter if you don't use th e R plug. If you have detonation issues with a 6 then swop to the 7 but it's better to rather have plug that cleans itself properly than one that is too cold and builds up gunk. So i use 6 until it proves to create issues. 7 tend to build up muck because they run too cold. Yes even if the engine is modified (short of turbo). But most people will simply change plugs at evry service which i don't do. I change them on condition so kind of care to keep them in good a condition as possible. Just my opinion.
I stopped using bosch after a series of failures on brand new plugs. Never had a single dead plug on ngk yet.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
Benitovw
Car Model: CITI ADY
Post by Benitovw » Tue Jan 10, 2012 4:49 pm
Thanx guys I'll use the BP7ES an just change them on every service
CITI 2L 8V
