vw golf 1 1982 Carb,overfuel,misfire,doesnt idle
Hi guys,my name is Naome I drive a golf 1 "82 Carb,lately my car is struggeling to start after a few attempts it slowely starts to idle but when I accelerate it dies,only rev's up if I accelerate a little bit but also doesn't want to idle,I must keep giving fuel and the fumes comes threw strong.Everytime I stop I must rev the car so that it doesn't stall,my car is also heavy on fuel lately,didn't have that problem before and started with one go in the past,took the carb off to clean and check for leaks but still struggeling with the same problem.Also strange when I want to turn left or right while driving it begins to stall as if its not getting enough fuel or power threw and again I must rev the car.what can the cause be,any advise will help please.Thanx
Re: vw golf 1 1982 Carb,overfuel,misfire,doesnt idle
Try replacing the rubber carb base and start there. If your problems persist get the car to a carb specialist and let them do their thing.
Don't ask your swaar to look at it, it will get worse.
Thanx,changed the rubber base a few months ago because it was leaking after that the car was fine,even 2nd stage was opening problem started in Dec when I broke the cv,standed for a week and began struggeling to start,car also feels lazy
- Registered for: 14 years
As missioner mentioned, check the carb base. Even if it is fairly new, it may have developed a leak or crack again.
Heavy fumes could be coming from the leaking base or check if the second stage is not stuck resulting in flooding.
Is choke functional and open?
Will check,do u think by putting another carb on aswell just to see if the problem continues will be advisable? I haven't used the choke since I bought the car 4years back,my bf builded the carb from scratch that time and its the first time I'm having this problem,the spring on the back of the carb came of but replaced that with a new 1 aswell
Has the timing, rotor and distributor cap been checked?
- Car Model: VW Golf Plus 1.4 BUD 2007
I had a similar problem many moons ago, the fuel pump on the front of the block rattled loose .
Ex : Polo Vivo, Renault Clio 3 1.6, Renault Megane and Scenic 1.9dci, Renault Clio 3 1.4, Renault Clio 2 1.4, Peugeot 308, Mini Cooper R56 1.6, Polo Tdi 1.4, Jetta 5 2.0 Tsfi Sportline, Ford Focus 2.0a, Bmw 320d E46 f/l, Citi Golf Chico 1.6, Corsa 1.7d converted with Gsi 1.6 engine, BMW X5 3.0im, Bmw 328 E36,Opel Kadett Ts by Group N Opel team, Jetta Vr6, Bmw 316i E36, Astra 160ie, UNO Turbo by Rudi, Bmw 325i Turbo by Alpine, Golf Gti16v exec, Mazda 323 Egi, Bmw e30 318i f/l
- dazza
- Car Make: VW and VW
- Membership No: 1327
More than likely an air leak somewhere. is the bolt that connects from the airbox to the top of the carb tight, those threads often give issues and then the top of the airbox pops off slightly
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
