PROBLEM WITH TURBO 2.0T BWA
- Wheel Whore
- Car Model: 2.0T A3 & Q7 3.0TDi
Guys,
I did the downpipe on Saturday on my A3 2.0T at Patrix Service Center.
I was told that there is play on the turbo shaft and oil is leaking past it into the exhaust.
I now have excessive oil smoke.
Would I need to replace the turbo or is there any other way of fixing the problem.
I called Mr Turbo and they only supply a balance turbo core for R3000
Turbo Exchange wants R10687 for a brand new turbo.
Any help will be highly appreciated.
Yuben
Yuben
2013 Audi Q7 3.0TDi S Line
2006 Audi A3 Sportsback 2.0T S-Tronic Ambition FRC ECU & S-TRONIC TUNED
Re: PROBLEM WITH TURBO 2.0T BWA
Speak to gaby at fastec and ask whatbhe can do for you.
0829224233
0829224233
- Wheel Whore
Thanks Bud, will call him now
- smitbrandon
Sorry for jacking the thread.panic-mechanic wrote:Speak to gaby at fastec and ask whatbhe can do for you.
0829224233
Panic seeing as the Gent mentioned that there is play on his turbo, is there any measurements or upgrades one can do to lengthen the lifespan and increase the longevity of the turbos internals?
No.
Use good oil, don't drive like an ass, let it cool down before shutdown.
Those are about all the things you can do.
- Wheel Whore
Spoke to Fastec who advised that the manifold will probably be cracked due to the mileage which is common on these cars.
Decided to just bite the bullet and get the new one which comes with the new manifold which Morne will fit
Why not just get a K04?
Audi TT Quattro project
BMW M235i (RIP)
Golf 7 GTI (Revo 2)
Golf 6 GTI
Ford Focus ST225 (Revo 2)
VW Polo 1.6
BMW M235i (RIP)
Golf 7 GTI (Revo 2)
Golf 6 GTI
VW Polo 1.6
- smitbrandon
Thankspanic-mechanic wrote:No.
- smitbrandon
In the end you will have peace of mind budYUBEN wrote:Spoke to Fastec who advised that the manifold will probably be cracked due to the mileage which is common on these cars.
- Wheel Whore
Am I right in saying that a KO4 option will involve much more mods and costs as opposed to just replacing the K03?bully wrote:Why not just get a K04?
It's the wife's car after all, downpipe and software is sufficient I think
You can get a k04 in reasonably good condition for R6500. Dv relocation is about R2000 and then you'd just need an intake and change your tune to stage 3.YUBEN wrote:Am I right in saying that a KO4 option will involve much more mods and costs as opposed to just replacing the K03?bully wrote:Why not just get a K04?
BMW M235i (RIP)
Golf 7 GTI (Revo 2)
Golf 6 GTI
VW Polo 1.6
BMW M235i (RIP)
Golf 7 GTI (Revo 2)
Golf 6 GTI
VW Polo 1.6
- Uncle Nunda
- Post Whore
- Car Model: S3
- Membership No: 1489
he would still need injectors, cooler & new zorstbully wrote:You can get a k04 in reasonably good condition for R6500. Dv relocation is about R2000 and then you'd just need an intake and change your tune to stage 3.YUBEN wrote:Am I right in saying that a KO4 option will involve much more mods and costs as opposed to just replacing the K03?bully wrote:Why not just get a K04?
ohhh yeah, tfsi would also need injectors. Same downpipe would work, cooler isn't really needed.Uncle Nunda wrote:he would still need injectors, cooler & new zorstbully wrote:You can get a k04 in reasonably good condition for R6500. Dv relocation is about R2000 and then you'd just need an intake and change your tune to stage 3.YUBEN wrote:Am I right in saying that a KO4 option will involve much more mods and costs as opposed to just replacing the K03?bully wrote:Why not just get a K04?
BMW M235i (RIP)
Golf 7 GTI (Revo 2)
Golf 6 GTI
VW Polo 1.6
BMW M235i (RIP)
Golf 7 GTI (Revo 2)
Golf 6 GTI
VW Polo 1.6
Just replace like for like in that application. Stupid to spend a ton on upgrades on a car that is not used in that way and add risk to something thatnshould be a simple turbo swop.
- Wheel Whore
Thanks Guys for all the help. Just received the turbo and waiting for Morne for fitment.
- Wheel Whore
Ok an update on the situation, the new turbo was installed on 27/07/2018. Morne informed me that a lot of oil fell into the exhaust system and there will still be smoke, I need to drive for about 500km or so to clear out the oil.
My concern now is that I have done around 800km and the smoke hasn't cleared.
The smoke is only visible on take off after idling, nothing in gear.
Morne said he will check it up when he has a gap, but for now I am worried that the car may have another problem causing the smoke.
Note that the excessive smoke only started after I installed the DP on 19/01/2018.
Any ideas?
Any ideas?
- Car Model: Sportline
- Membership No: 3194
Floor it for a few runs?
- Wheel Whore
Smoke is always there, more so when you floor it.....
- Wheel Whore
Any ideas, could it be a problem with the head, or oil rings ?
- Wheel Whore
oh, and the mileage is 169000km, well maintained prior to me taking ownership.
It could be either pistons, broken ring landing or the head yes.
Remove spark plugs and see if they are maybe all wet or one worse then the rest.
Do a compression test.
- Wheel Whore
Thanks. The surprising thing is that I had no smoke on Saturday for the entire day. In the evening, I had a few spirited drives, then on Sunday morning the smoke is back....
Note it is not excessive, just a puff.,,
- Wheel Whore
Can you recommend where I can get this done ?panic-mechanic wrote:It could be either pistons, broken ring landing or the head yes.
Do the tests. Report back.
I have no idea in your area. I do this stuff myself so can't tell you where to go.
Speak to morne.
Speak to morne.
- Wheel Whore
Thanks, after sorting out the DV last Wednesday, Morne said that the smoke doesn't seem normal, but to give it another 400km and then he needs to assess.
I must say, the smoking has decreased quite a bit from when I first replaced the turbo.
Like if i now am standstill and rev it slightly, I don't see the smoke rising, yet before if I had to do the same, the smoke would come to the front depending on the wind direction and is very noticeable through the passenger side mirror...
