golf 4 leaking power steering fluid
golf4ever
Registered for: 21 years 4 months
Car Model: TT
Post by golf4ever »
My girlfriend is dripping power steering fluid.
I refilled it 6 weeks ago and now it's completely empty.
Any ideas what I need to fix.
Thanks a lot. ..
2012 Land Rover Discovery 4 3.0T - White rolling on 19's
2007 Audi TT 2.0T - Grey rolling on S5 19's
2001 Golf IV GTi 1.8T - Black rolling on Oz Palladio 18's
1984 Golf 1 GTi 1.8 - Silver - My new baby
Aslam_mk4
SO FLUFFY, WE ALL GONNA DIE!
Membership No: 1824
Re: golf 4 leaking power steering fluid
Post by Aslam_mk4 »
Check the pipe for the power steering
Mine also had a leak and we changed the pipe if I remember correctly
Bagged mk4 2dr
"Ride or die"
TDi Tuned
Car Make: VW Golf V
Car Model: GTi (BWA)
Post by TDi Tuned »
First step is to check where it is leaking from, if its leaking from the pump reservoir
then it could be a pipe thats loose if so you lucky just tighten. However the
chances are that a pipe suddenly got loose is unlikely.
Secondly and more likely its leaking from the rack end boot (plastic dust
cover that fits over the rack end), if so then the steering rack is shot.
If this is the case, avoid driving the car, if the fluid drains out you can
strain and damage the power steering pump which is costly.
It is unlikely that the steering rack is leaking anywhere else but from the boot,
theres only one metal inflow line.
Your options on the steering rack is:
Brand new - R 15k
Recondition your steering rack - R 5k (only done a power steering specialists)
Second hand steering rack from a scrap yard - R 3k - R 6k (depending on condition)
If the pump breaks then brand new = R 10k
You cannot recondition the pump as it is an electric driven pump.
Second hand pumps can be found at scrapyards.
Hope this helps,
VW Golf V GTi DSG: BWA - Spec
CPi Tuned
CPi Intake
Downpipe by Primaforce
163kw, 309nm - DP Only (Experience Exhausts/APR KZN)
VW Polo 9n3
1.9 TDi PD100 (Highline)
CPi Tuned
Downpipe & Exhaust by Primaforce
PD160 Intake with BMC Drop in Filter
Front Mount Intercooler
127kw, 366nm (Experience Exhausts/APR KZN)
www.CPiTuned.co.za
zaheer.lari
Registered for: 12 years 8 months
Car Model: mk4 2door
Post by zaheer.lari »
thank you for the help , seem to also be losing power steering fluid
VELO-GP
Car Model: MK4 GTi
Membership No: 1870
Post by VELO-GP »
golf4ever wrote:My girlfriend is dripping power steering fluid.
Thanks a lot. ..
The leak usually occurs on the pipe in the front, behind the radiator (where the sensor plugs in) - both my Mk4's had this issue. (worth a look)
crashtestdummy
Registered for: 17 years 9 months
Post by crashtestdummy »
Thanks a lot. ..
+1- mine was leaking from the sensor itself..its r198 at GW...
4connie
1.8 Golf 4 Automatic
Post by 4connie »
Hi
I have a problem of a rattling sound right under my feet every time I take a corner,sometimes the idling is very funny,
I need help please
