What boost are ur guys 1.8T running Stage 1 or Stage 2
icemanwp
Registered for: 10 years 6 months
Car Model: Polo Gti 1.8T
Post by icemanwp »
What boost are you guys running, also with which tuner? Im with Sto (in Cape town) and im on Stage 2 but map isn't aggressive, don't think im boosting that high, still need to check.
Polo Gti 1.8T Stage 2 Sto tuned
63mm Sto custom downpipe
Honda s2000 filter
Stompie
Boostleak Guru
Registered for: 12 years 9 months
Car Model: 2006 120D
Membership No: 1843
Re: What boost are ur guys 1.8T running Stage 1 or Stage 2
Post by Stompie »
Im with Unitronic stage 2 map, Currenly boosting 1.2bar but have boost leaks i still need to find.
Used to peak 1.4bar and taper down to 1.1 bar.
BMW 120D E87
icemanwp
Post by icemanwp »
Im running Stage 2 with no Tip or Diverter valve (Map not aggressive) but after 4000rpm or so in third guy, power seems way lower, would adding a Dv help with this?
Honda s2000 filter
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
Get your self a boost gauge, then you can see what happens. It will point to you if you have a boost leak or tapering off too quick.
Might be a boost leak, dv not holding pressure or wastegate spring that has become too weak and opening up with high boost.
BMW 120D E87
icemanwp
Post by icemanwp »
Thanks man, im still on the original Dv would the Forge 007 Dv help with this?
Honda s2000 filter
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
The forge DV is awesome and will last for years and years! The stock one is prone to failure or leaks.
but you need to check if that is the actual issue or not, might be, might not.
Could be that its not holding boost or being able to stay closed under boost as its got a weak spring.
BMW 120D E87
RPGTI
Car Model: '13 PGTI DSG
Post by RPGTI »
Uni stage 2 peaking at 1.38bar boost, guess you can round it off to 1.4bar
'13 Flash Red Polo GTI
Ex.
'08 Flash Red Polo GTI
ACiD_Omega
Car Model: 2004 Chico under construction
Membership No: 1820
Post by ACiD_Omega »
Just for clarity and stuff, please state if you are using K03 or K03S please
VELO-GP
Car Model: MK4 GTi
Membership No: 1870
Post by VELO-GP »
I'm with FRC stage 2 map, Currently boosting 1bar.
MouseGTI
Car Model: B8 2.0Diseasel
Post by MouseGTI »
VELO-GP wrote:I'm with FRC stage 2 map, Currently boosting 1bar.
FRC maps must not be aggressive then... based on the guys that are on stage 1 already getting to 1.2/3 bar
White '07 Polo GTI 9n3 - Stock
Black '07 Polo GTI 9n3 - 113fkw 234nm stock -> 153kw 277nm chooned
Silver '07 Slowdi A4 B7 1.8t - w/ T3T4 powers
Green '16 Kawasaki Z300 - 28kw :crazy:
Blue '15 Yamaha MT-07 - 55kw :lol:
Blue '13 B8.5 A4 2.0TDI - 130kw :driving:
VELO-GP
Car Model: MK4 GTi
Membership No: 1870
Post by VELO-GP »
LOL! You don't need to boost high to make power.......
MouseGTI
Post by MouseGTI »
never said you have to
icemanwp
Post by icemanwp »
@My-gti what are u boosting, i knw Cpi does boost high. What power u making on the coast?
Honda s2000 filter
MouseGTI
Post by MouseGTI »
icemanwp wrote:@My-gti what are u boosting, i knw Cpi does boost high. What power u making on the coast?
honestly at the moment i have no idea. i really havent time to go to CPI in months for anything. i'm in the process of getting a boost gauge fitted...then i'll check that and compare with what CPI has on my car....any numbers i say now will just be me grabbing numbers....i could quote from Torque Pro, but no idea on the accuracy. it gave me 1.3bar many many moons ago...could be changing software also in the year so who knows...
RPGTI
Post by RPGTI »
When I had FRC on my car same setup as current apart from the wmi,throttle pipe and proper forge tip I was boosting the same 1.3/1.4bar. Although I do agree its not the only way its the easiest way to increase power but still operate within safe boundries for constant use.
Ex.
donsterza
Registered for: 12 years 4 months
Post by donsterza »
I have unitronic stage to If its nice and cold it will spike at 1.5 bar and then drop down to 1.2ish ko3s seat ibiza cupra
Bev0_tsc
Registered for: 11 years 7 months
Car Model: '08 Polo Gti
Membership No: 2087
Post by Bev0_tsc »
FR&R stage 2 , peak 1.3
Bagged '12 Edition 35
Bagged '08 Polo Gti
IR Tuned
My CW PGTI
My CSG ED35
cpichiptuning
WRD Service Centre - CPi Chiptuning
Car Make: Chev
Car Model: Lumina UTE SS 6.0L, + audi S3
Post by cpichiptuning »
icemanwp wrote:What boost are you guys running, also with which tuner? Im with Sto (in Cape town) and im on Stage 2 but map isn't aggressive, don't think im boosting that high, still need to check.
very easy to check, ask your tuner to take logs and make a print out, you can see all the boost at different stages on the logs. Your ECU will change boost and timing if some condition is not perfect, age of turbo can cause lower boost, boost leaks, its not easy to diagnose a problem for not fiscally seeing the carvery easy to check, ask your tuner to take logs and make a print out, you can see all the boost at different stages on the logs. Your ECU will change boost and timing if some condition is not perfect, age of turbo can cause lower boost, boost leaks, its not easy to diagnose a problem for not fiscally seeing the car
Killerwatt
Car Model: S3
Post by Killerwatt »
Mines goes to 1.3bar with no spike at 2500-3000 then tapers off to 1.1bar at redline.
pluto
Registered for: 20 years 6 months
Post by pluto »
Torque controlled ECUs , load is the key function - Boost is one of the factors that createlod but not the only factor.
The ecu has a whole toybox of goodies it can use to create load - You need to know which ones to change to get HP and Nm
After a certain point , boost is only hot air
Shiver me Wastegates
Frieling Racing Chip tuning
Yashin@frc.co.za
082 805 9060
2013 TT-RS S Tronic
MK1 20VT BAM (Motronic ME 7.5 DBW)
Registered for: 17 years
Post by dood786 »
1.3 bar on revo 2
boost'd
Criminal Troll.
Registered for: 13 years 4 months
Post by boost'd »
1.3 on RK
Taz0
Registered for: 12 years 8 months
Car Model: Polo 9N3 2.slow
Membership No: 1925
Post by Taz0 »
1.3bar on Revo 2
Mk1 Citi golf
Mk5 R32
Mk4 golf 3.6 4motion
nicholas mk3
Car Model: 2015 Golf VII R
Post by nicholas mk3 »
1,4 bar on FRC stage 2
Breadroll
Car Model: A3 1.8T
Membership No: 1989
Post by Breadroll »
1.6bar Unitronic Stage 2+
