2l 8v map dicktator
- Registered for: 6 years
2l 8v map dicktator
Can anyone please send a startup map for the 2l 8v crossflow , standard dicktator system , 298cams , ported for more compression . Long block , electronic distributor ...much appreciated.
Re: 2l 8v map dicktator
Try posting this request in the WANTED section under your own heading.. You revived a year old thread.8v crossflow wrote:Can anyone please send a startup map for the 2l 8v crossflow , standard dicktator system , 298cams , ported for more compression . Long block , electronic distributor ...much appreciated.
How do I do this?PapaJo wrote:Try posting this request in the WANTED section under your own heading.. You revived a year old thread.8v crossflow wrote:Can anyone please send a startup map for the 2l 8v crossflow , standard dicktator system , 298cams , ported for more compression . Long block , electronic distributor ...much appreciated.
In the classifieds section you can select "wanted" and then create the post. Might give you more exposure or edit jour heading by adding " wanted" to it and the moderators will move it for you to the correct section.
Oh I see , thanks , will do.PapaJo wrote:In the classifieds section you can select "wanted" and then create the post. Might give you more exposure or edit jour heading by adding " wanted" to it and the moderators will move it for you to the correct section.
