Re: 2L 8v Dicktator map wanted
Can anyone please send a startup map for the 2l 8v crossflow , standard dicktator system , 298cams , ported for more compression .
- ☆KalaMK3
- Car Model: MK3
Re: Re: 2L 8v Dicktator map wanted
What block? Mechanical/electronical dizzy?
Sent from my SM-G900H using Tapatalk
it's a electronic distributor , and a long block.
☆KalaMK3 wrote:What block? Mechanical/electronical dizzy?
Did you try loading the startup map from the Dicktator CD? The 1800 8V map on the CD should work too, to get it started and then can be adjusted form there.
Do you have the 4 window distributor installed in the block?
Some 2L long blocks came with single window and internal 60-2 trigger wheel.
I tried the 1800 8v map it's starts up thanksPapaJo wrote:Did you try loading the startup map from the Dicktator CD? The 1800 8V map on the CD should work too, to get it started and then can be adjusted form there.
You're welcome. Glad you could start up.8v crossflow wrote:I tried the 1800 8v map it's starts up thanksPapaJo wrote:Did you try loading the startup map from the Dicktator CD? The 1800 8V map on the CD should work too, to get it started and then can be adjusted form there.
