polo 9n3 1.6 ecu not getting power
- Car Model: jetta vr6
Hi...can anybody assist me pls...which relay or fuse powers up the ecu on a 9n3 1.6 polo....
ecu has been tested on another car and is working...
Ive checked on google and they mention a 428 relay...but I dnt have a 428 relay, I only see a 100, 489, 404, and 167...
Re: polo 9n3 1.6 ecu not getting power
Use a mulitmeter and trace the power wire form the management back to relay pins. That way you know which one it is.
Hi panic...discoverd the ecu is fried....what could have caused the ecu to burn....the autolek was just supposed to sort out the accerator pedal
a short, power onto an erath wire . welding on the car. incorrect jumper, many things. Ask the oke that worked on it.
Hi panic what's my best option now...will management work or should I look for another ecu
083 3095033 - trevor greene. ask him to get you a box and see if he can clone your's settings onto another.
Thnx panic
update...
I got a working coded ecu....the throttle is working and pedal is responding now....only problem now is thr is no spark and fuel pump not priming.....I hooked up my vag-com and the only faults that appeared were the throttle and accelerater pedal, I cleared them and nothing returned..,so what could cause no fuel and spark..
- amstel18
- Car Model: Tiguan Allspace
Was the ecu coded to your car? Could be the immobiliser is cutting the spark
Sent from my HUAWEI VNS-L22 using Tapatalk
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
the autolek I bought the ecu from said I should bring the old box to code the new 1....
so the ecu was coded without the car bieng present
Are you seeing rpm when you crank it in vcds? Does it show the immobiliser is not active.
hi panic .....I got it started....but now it not firing on 1 and 4.....I tested the coil on another polo and its working perfectly......
- Registered for: 6 years
Hi sorry guys im having a problem on my 2005 polo bah 1.6. i know its off subject but i need help , yesterday while driving the epc light comes on and it loses power wont go pass 3000 rpm , i read on vw club that its the brake pedal switch , i removed the lug and disconnected the battery hoping to clear the epc but instead the car now has no spark and refuses to start can anyone help would appreciate it
without being able to test if the management is putting out a signal it is hard to say. You need to use and led and test if the channel for 1,4 is being fired by the management box
thanks....panic
- Neuk
- Treasurer
- Membership No: 806
This may or may not be related, I have had two issues with cars and ECU's over the years...
I had a 1996 Mercedes Benz C180 Classic which while I was on the way somewhere died completely and suddenly, nothing in the car would work including lights, radio, etc. It turned out the ECU fried itself and had to be replaced.
I had a 2004 Audi B6 A4 Avant that we couldn't communicate with the engine ECU via the OBDII port. @JVR and I started doing some basic electric connectivity testing one Saturday morning to trace where the fault was. JVR asked me to retest something as he thought he had bumped a connector and so put it back on properly. We managed to connect to the ECU after that so the issue was simply a connector not on properly.
