Really Depends on the dyno and if you are referring to engine convert kw or wheel.
But I literally gave all the steps it takes. It just depends on the money you want to spend.
2l 8v rebuild to aleast 110kw
Re: 2l 8v rebuild to aleast 110kw
@missioner original motor is a 1.4i BLM
APK will not be a straight fit.InquisitiveKid99 wrote:@missioner original motor is a 1.4i BLM
You will need the following:
Engine and gearbox mountings
Gearbox
Clutch and flywheel
Ancillaries, ie: alternator, A/C pump, etc
ECU
Engine loom
Gear cables
Air box
Exhaust
Driveshafts
Brakes
That's what I can think of off the top of my head. It's most likely more.
Modding rule#1: don't build what you can buy.
Polo 2.0 9N3
So it would cost less to just buy the same motor and have that refitted.
ExactaberryInquisitiveKid99 wrote:So it would cost less to just buy the same motor and have that refitted.
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
At the coast 110wkw is achievable quiet easily...nothing super special needed.
Port & flow with keeping the valves standard
Stick something like a 288 with 11.7mm lift (Estas)
Option 1: Skim the head to raise compression to the desired limit obviously dependent on the fuel you want to run
Option 2: Deck the block to achieve the rise in compression which is what I will be doing on the next build
Run a proper branch and exhaust, don’t know if brospeed does anything decent now
Mp9 polo cup ecu or AMM
I Say you will be just shy of 110wkw unless your fuel mix is supportive to the above mods but you will be close.
Running my single throttle 8v on 35% Ethanol and 65% pump fuel I make 111wkw & 210nm, also taking into consideration that the comp I’m running is a lot higher
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Don't forget he will need "The special part" to make those figures
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- mike65
- Car Model: mk1
Ive spoken many times to him before but about 16v stuff...8v at the cost gets 110kw very quick...just need to spend afew bux and know what to dovwpro wrote:You can forget 110wkw on a na 8v motor, not possible with all the money you got. Only to achieve that figures is to do a dyno run on a happy dyno.
Speak to 8v performance, Sarel Ellof if reacable.
https://m.facebook.com/groups/171419086276082
Watch this space
Of course!!AlexTDi wrote:Don't forget he will need "The special part" to make those figures
