Vw mk1 carb help
Vw mk1 carb help
Hi. Need some advice. Fitted a weber 36dcd on my 1.8 vw fox but now there's no space for a filter as it will hit the firewall. Has anyone had a similar experience?
Re: Vw mk1 carb help
Classic problem with Weber installs.
Also if the baseplate is a little thick the air cleaner touches the bonnet.
Get the small airfilter housing that suits the carb, should solve your issue.
