Hi guys I'm struggling with my son's golf it starts idle for few seconds then switch off can it be immobilizer
1.6i Mk1
1.6i Mk1
Nezaam
'98 2.0 Polo-R 8v
'88 1.3 Fox (Foxy Cleopatra) - Project Trackcar
'98 2.0 Polo-R 8v
- Car Model: Mk5 Golf GTI
Re: 1.6i Mk1
That sounds like an immobilizer issue yes. The immobilizer cuts the fuel supply and this stops the engine.Nezaam POLO-R wrote:Hi guys I'm struggling with my son's golf it starts idle for few seconds then switch off can it be immobilizer
Can you bypass the immobilizer? Does the car have a coded key? It could have so.ething to do with this.
Sent from my SM-G925F using Tapatalk
- ItsGhost10153
- Car Model: 2002 Polo Playa
Re: 1.6i Mk1
I have a polo that does the same but i do not have an immobilizer installed in my car.
Re: 1.6i Mk1
polo had a key coded immobiliser from the factory so yes it does unless you had it coded out of the management
Re: 1.6i Mk1
Try the spare key if you have one.theunis.visser wrote:That sounds like an immobilizer issue yes. The immobilizer cuts the fuel supply and this stops the engine.Nezaam POLO-R wrote:Hi guys I'm struggling with my son's golf it starts idle for few seconds then switch off can it be immobilizer
If not then call a locksmith or a Mack with the computer that can recode the keys.
All the keys must be coded at the same time, any missing ones will be erased and no longer work. This is a good time to buy a spare key if you need one.
