Hi guys would just like to know if a golf 4 starter would fit on my ffz gearbox running agg motor.
Reason for asking, ive fitted the motor recently and tried starting it today but it swing really slow almost like the bat is flat.
I have my bat on charge now as its been standing awhile now...hoping i dnt have to replace the starter
stater motor upgrade
- mike65
- Car Model: mk1
Watch this space
Re: stater motor upgrade
If the golf 4 has the 02a style gearbox then no.
- mike65
- Car Model: mk1
So it has to be an 020 box?panic-mechanic wrote:If the golf 4 has the 02a style gearbox then no.
Watch this space
yes
Don't fit the Golf 4 starter.mike65 wrote:Hi guys would just like to know if a golf 4 starter would fit on my ffz gearbox running agg motor.
I have done it before and it does fit and turn the motor. It sounds very rough on cranking. It DAMAGES the flywheel teeth as it pushes about 3mm deeper than the 020 starter and the end of the starter gear bites into the 020 flywheel past the gears on the flywheel. You will end up replacing the 020 flywheel due to this causing the teeth to wear off in the flywheel. It will not last you a 1000km.
- mike65
- Car Model: mk1
Which starter would be perfect for my needs?PapaJo wrote:Don't fit the Golf 4 starter.mike65 wrote:Hi guys would just like to know if a golf 4 starter would fit on my ffz gearbox running agg motor.
Watch this space
any of the geared versions that was in a citi golf. They are perfectly fine. Buy them brand new for cheapish at goldwagen
- mike65
- Car Model: mk1
Allright thanks panic ill get one next weekpanic-mechanic wrote:any of the geared versions that was in a citi golf. They are perfectly fine. Buy them brand new for cheapish at goldwagen
will give an update
Watch this space
