Afternoon forum
I am planning on putting a 2lt 2E in the Chico.
Will attempt to run the 40 dellorto's on there.
Can I fit a crossflow head on the 2E block? This will give me much more space for the sidies.
I know the crossflow motor is not a direct fit - need to change mounting points.
AC
8v cross flow head
Re: 8v cross flow head
yes x-flow head fits on 2E. small mods to the head is needed.
Thank you Panic - found usefull information using search option.
Hi I would like to know if crossflowing a 2E head can be done.
Sure.
Remove stock U-flow head. Fit crossflow head. Done.
