2.0 APK conversion
- Ansell
- Registered for: 9 years 6 months
- Car Model: 1997 Golf 3
Re: 2.0 APK conversion
Hey man.
Ja thats going to be awesome.
Im sure youre excited to see how it goes.
Be sure to post your results, im keen to see.
Wow, really?
Thats impressive considering its a MK3.
So its basically a fresh 1800 now?
Wow, really?
1997 Golf MK3 GSX (1.8 MP9)
Specs:
79.7kw at 5209rpm and 160nm at 4240rpm (Saichs Dyno)
Modifications:
Stock exhaust with one 50mm-57mm freeflow box.
Standard airbox
Standard cam
Ex: 1970 Beetle 1300 twin-port
If you don't look back at your car after you park it, then you own the wrong car.
Specs:
Modifications:
Standard airbox
Standard cam
@ Panic-mechanic ,...seems you know your stuff around these APK engines ,...I have some mechanical knowledge ,but complete newbie on the ECU side of things ,..wondering if you or anyone could help .
So I have removed the BGU 1.6 motor from my 2005 Caddy kombi to replace it with an APK/AQY 2.0. It looked like a straight fit but have run into some snags. 1.6 was pap so opted to get more torque from a 2.0 hence the APK as I am looking for reliability.
The issues I'm sitting with is that I can either flash the current ECU for Golf4 MAP or go aftermarket ECU ,... problem is that harnesses are different and I would like to keep the ETC whereas the APK was a manual one. You have any suggestions on what could be done here or what I need to look out for wrt other problems?
- Car Model: Polo Playa 6n
Would there be any fabrication needed for the engine mountings? I want to fit the apk in a Polo millennium
Online
- Car Model: VW Caddy 2K 2.0 8v
I'm looking to do the same conversion maybe next year, just for more torque. Everything thing should be a straight fit but I'm going to use my 1.6 bsf plastic intake on the 2.0 apk just cause it looks cleaner. I will be going with dastek uniQ for the fueling.
2008 VW caddy panel van 2.0 8v
2012 Nissan Pathfinder 2.5 Dci Le
should bolt into a polo milennium just fine.
- Mk1Crazee
- Car Model: 1980 Mk1 4 Door 2L8V
isn't the Mk3 originally Digifant? using an Air-Flow-Meter?
1989 VW Fox 1800 (Sold)
1985 Ford XR3 1600Sport (Restoration Sold)
2004 Mk1 Golf 1.4i Velo Motor (Sold)
1980 Mk1 Old School Golf 2L8V
Shallow Pockets. Backyard Builder
There were a few different systems across the MK3 life (and model) span.Mk1Crazee wrote:isn't the Mk3 originally Digifant? using an Air-Flow-Meter?
Digifant, Semos (sp), MP9, ME7 (in the VR), etc.
Siemens Simos
Ah, thanks. Explains why I couldn't find the correct spelling in Google - I thought it was also Bosch.panic-mechanic wrote:Siemens Simos
- dubz-on-drugz
Hey bud ... so i got around to tuning mk3 ..it made 100 wheel kw and trust me it's awesome .I'm soon going 2l crank that a mate of mine so generously gave to me .Ansell wrote:Hey man.
Wow, really?
And the best part is .a mk3 really gets more attention and far more appreciated then the mass produced golf 1.I have both mk3 and mk1 and the comfort levels can't be compared .
If u want a lil more of a laugh when driving ur car i believe the key is the head work I feel ..yes the 2l block and torque will be nice ... but I can tell you this much a 1800 is a far more rev happy engine which I find more fun to drive .
Hope you cabbie progress going good !
Cheers
- Car Make: VW/ Audi
- Car Model: MK3/ 500 turbo
How zit gentle men i'm still new here, i also drive a Golf 3 1.6.. whoo hoo does not have the power my Audi have but at least it does not suck the juice that fast lol,correct me if i'm wrong a APK motor will be a straight fit in my Golf, will it bolt onto my gearbox as well and must i get a bigger clutch? I'm looking for a bit more power thats it, or just go for a 1.8 ( put in a 1.8 crank and pistons keep it carb)?
Thanx
Thanx
- dubz-on-drugz
I think you are faced with the same question . How much power comes with a cost factor .on a normally aspirated engine it's generally more $$$$ to kw. I but yes 1.8 setup. torque Will improve a bitfastfaan1 wrote:How zit gentle men i'm still new here, i also drive a Golf 3 1.6.. whoo hoo does not have the power my Audi have but at least it does not suck the juice that fast lol,correct me if i'm wrong a APK motor will be a straight fit in my Golf, will it bolt onto my gearbox as well and must i get a bigger clutch? I'm looking for a bit more power thats it, or just go for a 1.8 ( put in a 1.8 crank and pistons keep it carb)?
Thanx
yes bolts onto the same box . First look at the clutch when you take it out. Some mk3 already hade the 210 mm clutch setup even if it was a 1.6.
I see Mikes place have them on special for R5900,00 - bargain for a APK.
- dubz-on-drugz
Is it fair to think the apk conversion is only cheaper if you already have the correct management ?DeanK wrote:I see Mikes place have them on special for R5900,00 - bargain for a APK.
- ☆KalaMK3
- Car Model: MK3
Dont even go that route. Had so many issues on this swap and the power/money spent ratio is terrible. Invest in an ABF swap and get it over and done with. (Or 8vT). Motor bought ar R8.5k, rebuilt (piston play bought at japan auto) cost another R4.8k, dictator ecu R3.5k, tuning installation to date cost me R5.2k and I am pulling 72kw (with a 276cam). Honestly so damn upset over this.
- Car Model: MK3 Cli, MK3 CSX, MK1 GT
Why did'n't anyone just mention to go with mechanical carbs
'78 Mk1 2door - RIP
'79 Mk1 2door - New Project - Making a trailer from it - WIP
'96 Jetta CLi 2.0L 8v MP9 99.1 KW - 187 Nm with Zorst and Branch RIP
'94 Jetta CLi 2.0L 8V Stock standard (SOLD)
'97 Jetta CSX 1800 8v (WIP)
'89 MK1 4door Citi Golf - New Spec to Old Spec WIP
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Coz to old school, and the guys that know how to sort them proper are to old as well so help would be hard to find
If I had a MK3, it would either need to have 1.8 16VT or 2.0 16VT.
2.0 8V in a MK3 would obviously be better if you running either 1.6 or 1.8 but don't be surprised when can't get a new school 1.6 (eg. Toyota Corolla) of your back.
right ok bye!
