mk3 gti 2.0 8v ecu bosch wiring diagram
Hi Guys
sorry to high jack this conversation
I need a wiring diagram for the below
Golf Vento Mk3 III 3 Engine ECU Computer BOSCH # 0261200701 1H0907311
VW GOLF MK3 - ENGINE ECU - 0261203302 - 0261203303 - 030906026R -
I am not sure which one is correct but I have a mk3 gti 2.0 8v and it has a bosch ecu , I need to connect it back
does anyone know how too or where I could get a diagram from please
- Car Model: Polo 9N TDi Sportline, Jetta V
Re: mk3 gti 2.0 8v ecu bosch wiring diagram
Let me go look @ home this evening I think I have it
HI SUPERVLY
that would be great thank you !
- freezaburn
- Car Make: VW, Audi, Toyota,BMW
- Car Model: GTi,Citi Sport,Raider,A4, 316i
I have the wiring diagram for the Bosch Digifant system ('94).
If it's MP9 etc then perhaps someone else can assist? PM me your address.
All Current Rides:
-2009 Audi A4 (B8) 2.0T FSI Avant (155kw)
-2005 Audi A4 (B7) 2.0T FSI Avant (147kw)
-2005 Toyota Hilux D/C 2.7VVTi (118kw)
-1995 BMW E36 316i
-1994 Golf MK3 GTI 2.0 Exec (85kw)
-1986 Citi Golf Sport 1.6 (63kw)
HI Nivesh I only have US spec Motronic ecu they claim to be usingnivesh wrote:HI SUPERVLY
sorry man
hi Supervly
are they not the same ???
- General
- Car Model: Golf GT
- Membership No: 1464
I can give you the MP9 pin-out from my Velo. There is a small difference between the Citi and the Polo/Mk3 - rev counter picks up on pin 9 (green wire).
Current rides:
Hyundai - 1.4 Getz (daily)
I am a little confused. Was this a local sa spec gti 2l 8 v which now has an ABF or is a import that came with an abf?
If local then that should digifant and I am not sure it will work too well on the abf setup.
Which year model?
Which year model?
hi Panic
this is a local car the ecu says made in south Africa
it came with the 2.0 8v motor
I transplanted the abf motor
if I am not mistaken it is a 1998 executive sunroof from factory with the vr6 seats and has the sliver cluster finish not the old black one
Hi torker
thank you I will have a look at it thanks
panic
is digifant not fuel Dissepiment something without the fuel rail ?
That wiil be mp 9 then
And if the distributor is the actual issue you will be in exactly the same boat.
mine came with the fuel rail and green injectors
and no air flow sensor in air box
Yes mp9. Again, if the distributor is your current problem mp9 is not magically going to fix that.
yes I know and I understand ...
but I am going to get a 16v dizzy
and I just feel the after mark is not for me , I have had bad experiences so I feel I should just go back to mp9 with a vr6 obd2 t/b and a piggybag
as I need the car as daily runner , that is why I need it to be reliable and have little more power.
shaunbiker1978@gmail.comfreezaburn wrote:I have the wiring diagram for the Bosch Digifant system ('94).
Also needs diagram on jetta 2.0 8v cli bosh 1HS 906 258 2.0 ecu .
Thanx.
- freezaburn
Hi Shaun, Sent you an email...
All Current Rides:
-1995 BMW E36 316i
- Golfie.NC
- Car Model: 90kW Citi R-line 1.8i
Also need 2e ecu wiring pin out please graham.okkies@gmail.com
2008 Citi R-Line 1.8i
1996 Jetta VR6 Executiv ( Can call it a running project )
Projects:
Golf 3 GTS 16V Conversion
(AFV Block, 9A 2.0 16V Head & KR 16V Intake)
Projects:
