high heat gauge velociti - fan kicks in late
- araf69
- Car Model: 2008 MK5 GTi DSG
- Membership No: 1739
Fan only kicks in late around 3/4 but this only happens in traffic. When it kicks in the gauge drops from 3/4 to halfway. Normal citi driving and freeway doesn't go above half on heat gauge.
Advice. 4 pin temp sensor or fan switch.
If I'm correct you don't pick these up on vag
my rides thread : https://www.vwclub.co.za/forum/viewtopi ... 1&t=138629
2008 mk5 gti - Stealth Tuned
Ex 2005 velociti 1.6i
Ex 92 nissan 200sx 133 hp atw
Ex 85 mk1 ABF on ats cups - 122kw 198nm atw
Ex 04 2.0i ADY citi on BBS - 15.8s 1/4mile
Ex 00 Citi 1.6i 272cam TDi wheels
Ex 02 mk4 gti 19s RS6 wheels
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 92 uno turbo - 116 kW 222nm atw
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
Re: high heat gauge velociti - fan kicks in late
I'd say it is the 4-pin water temp sender. Non-OEM ones tend to over or under-read the temp on the cluster...
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Car Model: Polo 1.2 TSI
Sounds like a switch issue
Another mech advised its good to use a Peugoet (spelling) switch and then your fan kicks in sooner
Current: 1.2 Polo TSI 66KW
EX Polo Vivo Blueline
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- araf69
The gauge reads normal all the time. Just in stand still traffic it picks up to 3/4
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- General
- Car Model: Golf GT
- Membership No: 1464
I've seen this on my GT, there is a difference between the temperature where the thermostat opens (80 degrees) and the fan kicks in (90 degrees). Normal driving the temperature will be closer to the 80 degree mark but in traffic with no airflow the temps will rise to 90 degrees where the fan will kick in and bring it down again. This only started when I replaced the thermostat with an OEM 80 degree rated unit. The previous GW one was rated higher, closer to the fan temp so less fluctuation between the two temperatures.
Hope it makes sense...
Current rides:
Hyundai - 1.4 Getz (daily)
- Killerwatt
- Car Make: AUDI
- Car Model: S3
The 4 pin temp sender on the head has nothing to do with the rad fan, that is for ecu and cluster.
Thermostat issue will show up on the freeway too.
My guess is the fan is only activating at the second speed. There is the switch in the rad that controls the fan, the 1st speed should be 89'c and second close to 95'c. the fan activating at the higher temp will explain your probs. replace the switch on the rad and all should be well....
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
this...Killerwatt wrote:The 4 pin temp sender on the head has nothing to do with the rad fan, that is for ecu and cluster.
- araf69
Thanks killerwatt. Sounds about right
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- Membership No: 388
Cit should only have a single speed fan and switch in it.Mk2 and 3 had two speed fans in them.
Normal running temps on the citi is 96deg thats when the fan kicks in on first speed.If it had two speed fan second speed would kick in at 98 deg.
What dash is this car old or new dash.
Old dash did have habbit of over readin specially if non o.e switch used for sensor.Have you connected a vas or vag comm and looked to see what is the engine ecu reading and at waht temp the fan kicks in.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
- araf69
As stated its a velociti. Car is stock
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- araf69
pic of dash with heat gauge
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- Scatman
- General
- Car Make: BMW
^^^ That would scare me. Mine has never gone that high in the 7 years I've owned my car.
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
Yoh , Me neither..
I wish my fuel gauage would stay like that though..
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- General
The only time my Velo's heat gauge went over half (90) in 220000 km was when my waterpump failed...Scatman wrote:^^^ That would scare me. Mine has never gone that high in the 7 years I've owned my car.
Current rides:
- VELO-GP
- Car Model: MK4 GTi
- Membership No: 1870
I had the problem on my velo replace the switch
- Kiran
- Thumbie
- Car Model: Golf 1 Citi
- Membership No: 2028
i also have the same problem with my 2007 citi 1.4i, the fan does not kick in on time, it sometimes goes to the redline, then i have to switch off and let the car cool down
Kiran wrote:i also have the same problem with my 2007 citi 1.4i, the fan does not kick in on time, it sometimes goes to the redline, then i have to switch off and let the car cool down
Chnage the switch :tosser:
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Lord of the Sponge
- Membership No: 1676
Naku786 wrote:Kiran wrote:i also have the same problem with my 2007 citi 1.4i, the fan does not kick in on time, it sometimes goes to the redline, then i have to switch off and let the car cool down
Yoh yoh yoh
- Psycho8v
- Car Make: Toyota
- Membership No: 1881
But this isn't good to let the motor get that hot. Please correct me on this, but won't your head start to warp from the heat if it heats to the redline?
- Scatman
- General
- Car Make: BMW
That, and maybe burst water pipe. Definitely not goodPsycho1400 wrote:But this isn't good to let the motor get that hot. Please correct me on this, but won't your head start to warp from the heat if it heats to the redline?
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- araf69
Mine has got to 3/4 just twice and only in heavy traffic conditions.once the fan came on at 3/4 it went back to 90. Since I posted this 2 days ago it has never gone past 90 but I haven't driven in traffic since then.
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- araf69
Update on this is that the problem is solved. I will just have to monitor it for next few days. I removed the fan switch (no. 29 spanner) and I noticed rust build up by the switch.when I open the switch I taught water will be rushing out but It didn't. It just dripped out. I have flushed the rust out the radiator and added new coolant and put back the same switch. I idled the car till the fan comes on and it now comes on at 90 C
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- Scatman
- General
- Car Make: BMW
Great stuff!araf69 wrote:Update on this is that the problem is solved. I will just have to monitor it for next few days. I removed the fan switch (no. 29 spanner) and I noticed rust build up by the switch.when I open the switch I taught water will be rushing out but It didn't. It just dripped out. I have flushed the rust out the radiator and added new coolant and put back the same switch. I idled the car till the fan comes on and it now comes on at 90 C
Maybe buy some radiator flush and put it in the cooling system for a few hours and go for a long drive with the car. This should free up the rust/limescale buildup in the cooling system. Then basically let the car cool down and let the engine run with one of the water pipes disconnected and put a hosepipe in the radiator so that any loose crap can be circulated out of the cooling system. It seems like your cooling system is in a terrible state. Hope you get it clean buddy!
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
