Polo Classic 1.9 TDI rpms
- Registered for: 6 years
Hi everyone. The rpms on my Polo Classic 1.9 TDI always sit at 10 regardless of where the engine is cold or hot. Any advice's and pointers are appreciated. What is the normal rpm level when cold and when hot.
Re: Polo Classic 1.9 TDI rpms
903rpm, havnt really noticed a high idle when cold..
Common cause of this is a broken alternator wire (trace it from the alternator to around the starter area where it normally breaks)
- TDi4Life
Howzit man.. mine usually sits at around 900rpm when it's warm (maybe slightly lower) but there's a clear difference between when it's hot and when it's cold.. not sure what your issue could be but try and do diagnostics first and take it from there..sanelenanti wrote:Hi everyone. The rpms on my Polo Classic 1.9 TDI always sit at 10 regardless of where the engine is cold or hot. Any advice's and pointers are appreciated. What is the normal rpm level when cold and when hot.
Sent from my SM-J700H using Tapatalk
Thanks for your replies. I have then checked for broken wires as suggested but unfortunately I couldn't find anything. One mechanic said it's the airflow meter sensor, what he did he started the car and disconnected the sensor while the engine is running and he was expecting the sound to change which did not happen, it's when he said the sensor isn't doing it's job. Please advise if this theory is correct before I replace a sensor that is working.
- Car Model: Polo TDi
Check your car to see if u have a battery light on your dash...my car had this problem and as ashveer said it was a broken wire leading to alternatorsanelenanti wrote:Thanks for your replies. I have then checked for broken wires as suggested but unfortunately I couldn't find anything. One mechanic said it's the airflow meter sensor, what he did he started the car and disconnected the sensor while the engine is running and he was expecting the sound to change which did not happen, it's when he said the sensor isn't doing it's job. Please advise if this theory is correct before I replace a sensor that is working.
Sent from my ALE-L02 using Tapatalk
No warning lights on the dashboard, even diagnostic machine does not register any faults. One other thing that I noticed this morning, when I started the car the rpms were sitting slightly below 9 for 5 seconds or so then back to 10.
When u out the key on, BEFORE starting the car. Does the battery light come on?
Yes the battery light comes on and switch off once the car starts.
Gonna have to read scan data and look for anything unusual..
Any recommendations around Pretoria?
