Dsg gear issue
Dsg gear issue
Hi
Hoping someone can assist or advise. I have a tiguan 4m dsg, when i select D to drive it starts/displays D2. If i change to S mode gear starts/displays D1.
Anyone experience this?
- Registered for: 10 years
Re: Dsg gear issue
My friends Caddy is the same. Also 2.0 tdi. We recon the motor has enough torque to pull away in second, or so the dealers told him.
Sent from my Alpha using Tapatalk
- Car Model: S3, Polo Playa,
Re: Dsg gear issue
Your gear selector inside the car can be on its way out. By any change that some liquid been spilled on it?
- Car Make: Jaguar
- Car Model: X-Type 2.2D
Re: Dsg gear issue
That's normal. The Mercedes-Benz 7G-Tronic and 8-speed ZF transmissions do the same. Are you sure it displays D1 and not S1 when you put it in Sport mode?
Current: Jaguar X-type 2.2D
Ex: 2000 Citi 1.3
Ex: 2000 Citi 1.3
- dazza
- Car Make: VW and VW
- Membership No: 1327
Re: Dsg gear issue
Sounds weird...If you move it to manual mode and shift down does it change to D1?
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- Membership No: 2033
Re: Dsg gear issue
Happened to my R32....... flashing PRNDS of death, turned out to be shifter that was bad. I'd get it scanned and checked out......vwpro wrote:Your gear selector inside the car can be on its way out. By any change that some liquid been spilled on it?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Re: Dsg gear issue
if i move it manual it changes to D1.dazza wrote:Sounds weird...If you move it to manual mode and shift down does it change to D1?
Sorry yes it changes to S1 not D1 specific for S mode.tamper_man wrote:That's normal. The Mercedes-Benz 7G-Tronic and 8-speed ZF transmissions do the same. Are you sure it displays D1 and not S1 when you put it in Sport mode?
If i do a fault check, will it be able to pick up the fault?
Re: Dsg gear issue
bump anyone who can advise?
Re: Dsg gear issue
Have you scanned it, or taken to VW for a fault check?kbb wrote:bump anyone who can advise?
HOWIE-WP,
- Neuk
- Treasurer
- Membership No: 806
Re: Dsg gear issue
I don't see what the issue is? Many modern day cars will pull off from stand still in 2nd gear.
- Chuck_Norris
- Car Model: Polo 1.9 TDI
Re: Dsg gear issue
Nothing wrong with it. Tiguan TDI does switch to D2 rather on pull away. There is a firmware version update from VW that will force it to D1 every time. Some parts of the world had different gearbox settings. Like USA version does not display the current gear in die display.
Ex - 1.9tdi Highline
http://vwclub.co.za/forum/viewtopic.php?f=11&t=161270
Current - Tiguan 2.0T - 4 Motion
http://vwclub.co.za/forum/viewtopic.php?f=11&t=183069
Re: Dsg gear issue
Thanks all for the responses. Will have it scanned and see
- Car Make: Jaguar
Re: Dsg gear issue
I fail to see how that is a possibility - when he shifts into Drive, it shifts into D. When he shifts to Sport mode, it switches to S. The only way you can control which forward gear the car is in is with the M program (move the shifter to the left) or with the paddles. This is purely how the gearbox was programmed to react in normal driving conditions - it is not indicative of any fault in either the gearbox or the shifter and its related electronics.vwpro wrote:Your gear selector inside the car can be on its way out.
Ex: 2000 Citi 1.3
Ex: 2000 Citi 1.3
