Seized mk4 TDI alh ,advice needed
StormBringer101
Post by StormBringer101 »
My golf mk4 TDI recently quit on me with no warnings ,engine just stalled on highway and would not restart or crank manually . removed gearbox ,clutch hoping for small fix but they were fine .
No slipping on timing belt etc ,cambelt was changed about 8000km ago .no excessive smoking and normal High milage oil use and no coolant loss, . opened and pulled the head to find exhaust valve had broken and shattered . pictures of head and block . Is this repairable and from a cost point of view what would be better, I've been advised that a recon engine would properly be a better bet .ImageImageImageImage
Sent from my T1-701u using Tapatalk
Re: Seized mk4 TDI alh ,advice needed
Well it's a full recon anyway - yes head might be fixable - the injector is damaged which will cost around 2500 to fix - Bargain on around 15 to 20k if you do most of the labour except the engineering to bore block and fix the head.
Did one last year exact same valve.
StormBringer101
panic-mechanic wrote:Well it's a full recon anyway - yes head might be fixable - the injector is damaged which will cost around 2500 to fix - Bargain on around 15 to 20k if you do most of the labour except the engineering to bore block and fix the head.
Thanks ,so cost wise a recon will work out similar or less ,quicker turnaround ,but on recon no idea of actual condition .
Citi 007
Car Model: Citi 1.8i Ltd
Membership No: 1972
Post by Citi 007 »
Is buying an import from japan auto, etc not an option
It is IF you can find one. Very scarse and hard to find. They just don't seem to have stock of them ever.
Sure exchaneg recon but you don't know the quality of work/parts etc. etc.
VAG Fan
Post by VAG Fan »
Interesting, Stephan, that the one you fixed, failed on the same valve (exhaust #3). Do you reckon it's just pure chance, or might there be an underlying weakness? (Thermal issue, lubrication or whatever)
Veex....
Registered for: 9 years 1 month
Post by Veex.... »
You might as well buy another engine than fixing that engine.
Sent from my SM-A520F using Tapatalk
Current:Seat IBIZA FR
132kws 472Nm @ Stealth
RunX RSI
120kws 168Nm @ Rallycross
RXI 20v(bluespook)
111kws and 169Nm @ Autotrix
92 Gli Twincam 16
Chisel GLI Twincam 16
Mk2 1600 Sport Escort
StormBringer101
Busy looking for engines now . LDR seem to offer the best price/guarantees . Any one used them before .
Also not being able to open the engines up any tips to lookout for .
Veex....
Post by Veex.... »
How'sit man I know ldr are good. I have a friend there and very helpful. I got an an engine but mileage is high.
RunX RSI
RXI 20v(bluespook)
92 Gli Twincam 16
Tdi jetta 4 ever
Registered for: 13 years 5 months
Car Model: Jetta 4 1.9 Tdi, Isuzu2.5DKBLe
Post by Tdi jetta 4 ever »
New piston and head required. Then you can do a complete rebuilt.
Robin
robinwisse@gmail.com
StormBringer101
Thanks for all the advise guys. Not going to Repair etc. Rather cutting my losses and selling .
Veex....
Post by Veex.... »
StormBringer101 wrote:Thanks for all the advise guys. Not going to Repair etc. Rather cutting my losses and selling .
Where you based?
RunX RSI
RXI 20v(bluespook)
92 Gli Twincam 16
StormBringer101
Roodepoort. GP
