Hello
I think I have a leak by the injector loom and apparently this is a common leak on the PD motors. Would it be best to replace the loom or use some type of silicone to seal it again?
Regards
1.9 Sportline Injector Loom Leak
- Car Model: Sportline
- Membership No: 3194
Re: 1.9 Sportline Injector Loom Leak
If it leaks around the loom plug tthen sure silicone. If throught the plug then replace.
Thanks panic!
You have to open the tappet cover, unplug the loom, and replace the loom o ringbillionairebum wrote:Hello
Regards
2001 'rolla 160 gle (ex)
2005 old schooled caddy (ex)
1995 vw golf 1 ((ex)
I contacted VW and they only supply the full Loom with the gasket and plastic bit not the o ring separately that is why I asked if I could use something to seal it. Will try find the size of the o ring.LoW n SloW wrote:You have to open the tappet cover, unplug the loom, and replace the loom o ringbillionairebum wrote:Hello
Regards
You can get o-rings at places like bearing man etc that supplies bearings and seals.
