VW Touran 1.9tdi 2004
hi, I recently replace my Turbo on my 1.9tdi touran 2004 when this was done I picked up errors on the diagnostic machine that the Boost Sensor has fault, so I replaced it with a new Bosch sensor, but still the same errors and the engine still does not boost.
I unplugged the sensor and there is boost, but without the sensor plugged in the car is drivable, how is this working?
Re: VW Touran 1.9tdi 2004
Hi Guys, Any tech guru out there please can you assist with my post.
- Tdi jetta 4 ever
Can you place the scan results here so we can see. This way you might get some good advice.
Robin
robinwisse@gmail.com
If by boost sensor you mean the n75 it has 3 connections, and if it works with it disconnected. Then you have connected it wrong, check online for diagram, it could be faulty or you could have a blown n75 fuse, check driver side ok side of dash
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
thanks guys I will have this checked out..
hi Guys
Can you assist my alarm horn is not working and I want to replace it, where is it located?
also where is the power steering bottle allocated?
- Car Model: Touareg / Caddy / Polo / Citi
Alarm horn - If you are close to a dealer, take the VIN number to them and ask that they have a look on their PC. The schematics will give you an indication where to look.
Power steering bottle - Look for a small black reservoir with a green lid with a cut out on top, for the Jetta 4 TDi it was next to the water bottle and suspension turret. Otherwise, follow same steps as for alarm horn.
Anton van Graan
2009 Touareg 3.6 VR6
2007 Caddy Life 1.9 TDi
2004 Polo 1.6 Comfortline
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
1988 Ford Laser 1600i Sport
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
I might be very wrong but I don't think you will find a power steering bottle in a Touran, it uses the same chassis as the golf V which means electric power steering... there should be a servo or electric motor on the rack
I think you are correct.VGTI wrote:I might be very wrong but I don't think you will find a power steering bottle in a Touran, it uses the same chassis as the golf V which means electric power steering... there should be a servo or electric motor on the rack
It's the same engine used in our 2007 Caddy and it's electrical. I think the 2004 portion threw me and I looked at the wrong engine on Google...
Anton van Graan
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
Eish....guys I am new to the VW TDI engines and models...but any way dankie neh... for the info..
No problem, lots of knowledge here...Magito wrote:Eish....guys I am new to the VW TDI engines and models...but any way dankie neh... for the info..
What you can also do, is to take the engine series number as shown on your license disc, usually starts with 3 letters, and copy that to Google, i.e. AHF or BKB, etc. which should give you engine info and if you click on images, you can compare visually to what you have.
Anton van Graan
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
- Tdi jetta 4 ever
And what happened to the boost issue ?
Robin
