X Polo Tdi 6R - DPF Revoval
P1LAYA-ZN
Car Make: Audi, VW and Toyota
Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Post by P1LAYA-ZN »
Good day gents,
As I am soon to be taking over my gf's car, I would appreciate some advice.
The car will be around 150000 kms when I take it over and I was wondering if its advisable given the mileage for a 3 yr old diesel, doing the DPF removal ?
I've read up that this will help with saving the turbo, increasing fuel economy and power?
Is it worth doing, and what gains can be expected after doing a mild map ? Also, will the car start throwing out clouds of black smoke ?
#Builtnotbought
J.R Caddy
Car Model: MK1 Caddy
Re: X Polo Tdi 6R - DPF Revoval
Post by J.R Caddy »
Wont suggest removing the dpf, as it is not a normal catalyst. The management uses it. If you remove it , the warning lights will come on the dash and go into limp mode :type: the power will dissapear. Check in thle owners manual. It tells you how to burn it clean if neccesary. When it starts goetting clogged the dpf warning light will come on. Any vw can burn it clean for you using diagnostics. When the warning is active. If you do remove it. And therr are issues. To replace it will cost you in the area of 25k. :crazy:
MouseGTI
Car Model: B8 2.0Diseasel
Post by MouseGTI »
Will need software if you remove it....to keep the engine management happy
sent from small tehbo
White '07 Polo GTI 9n3 - Stock
Black '07 Polo GTI 9n3 - 113fkw 234nm stock -> 153kw 277nm chooned
Silver '07 Slowdi A4 B7 1.8t - w/ T3T4 powers
Green '16 Kawasaki Z300 - 28kw :crazy:
Blue '15 Yamaha MT-07 - 55kw :lol:
Blue '13 B8.5 A4 2.0TDI - 130kw :driving:
Punisher187
Car Make: Polo 6R
Car Model: 1.6 Tdi
Post by Punisher187 »
First thing you should do is remove the DPF(they remove the insides of it) then go to a tuner who will remove the dpf out of the software.The Dpf regeneration is a pain in the @$$
thabom99
Registered for: 6 years 1 month
Post by thabom99 »
Hi all
I have a clogged catalyst conveter and have found one at a scrap yard. Can I go ahead and replace it. I'm not a mechanic.
