When I bed my brakes they start smoking on the 5th or 6th stop out of 10, looks scary...moonwillow wrote:It was smoking. Almot looked like my engine was on fire
280mm bolt on Brake upgrade kits for MK1 is here!!!
- General
- Car Model: Golf GT
- Membership No: 1464
Current rides:
Hyundai - 1.4 Getz (daily)
- Pieta
- Car Model: 04 A4 1.8T 6spd S-Line
- Membership No: 1909
Mine did the same, just touched the carrier with a flap disc on the grinder, problem, no problem.ShafiqNC wrote:hey guys
i fitted this kit to my project but im having a small issue
the disc is sitting way to close to the carrier...
ive spoken to viper about this and he also hasn't experienced this before
anybody else seen this before?
any ideas as to why this could be happening?
both sides are doing the EXACT same
Pieter "Pieta" Oberholzer
-04 Audi A4 B6 1.8T
BT In process
Biltein + Eibach Sportline
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- Membership No: 1161
How did you get that right? Are you sure its not a fluid leak?moonwillow wrote:It was smoking. Almot looked like my engine was on fire
- moonwillow
- Car Model: 2L Caddy
How did you get that right? Are you sure its not a fluid leak?[/quote]
Well I installed a 288 deg cam and took the caddy for a spin. If it was fluid leak my brake fluid bowl level will drop and the level is still the same.
Current rides.
1998 VW Caddy 2L 8v.
2015 Renault Clio
ex rides.
1998 Hyundai Elantra 1.8
2007 Mazda RX8 Hi-Speed
2007 Chev Lumina SS 6L V8
2010 Mazda BT50 3L 4x4
2010 Hyundai Elantra 1.6
1999 VW Chico 1.3 Carb
2005 VW Caddy 1.6
2007 Suzuki GSXR 750
2009 Citi ROX 1.4i
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=159156
2015 Renault Clio
ex rides.
2005 VW Caddy 1.6
2009 Citi ROX 1.4i
Is this brakes still availible?
- Goldwagen Delarey
- Membership No: 1800
Yes we got plenty stock
Sent from my GT-N7105 using Tapatalk
Can you please pm me your contact details
- Goldwagen Delarey
Goldwagen Delarey
624 Ontdekkers road
Delarey
Roodepoort
0114779979
Or just send me a PM of what you need. We can do courier or postal orders 2
624 Ontdekkers road
Delarey
Roodepoort
0114779979
- Wheel Whore
- Car Model: mk1 2.0 8
Hi viper dd pm u nt sure u gt it im interestd in the brake upgrade
- Goldwagen Delarey
Hi Viper do you guts have this kit for a Polo 6n (1997)?
I have std size ATE discs that's slotted and drilled and maybe use EBC green pads with it .
- Goldwagen Delarey
Unfortunately nothingdubstar wrote:Hi Viper do you guts have this kit for a Polo 6n (1997)?
- yeo786
- Car Model: Velociti 1.6i
Price of this kit?
If you're in control, you're not going fast enough!
Current :
VW Velociti 1.6i
Ex -Honda Ballade EF 160i 16V Dohc - Sold
Ex -VW Citi 2.0 8V Carb - Sold
Ex -CitiRox 1.4i - Stolen
Current :
VW Velociti 1.6i
- Goldwagen Delarey
Polo cup discs A2674 (GW Part number ) R860.00 per setyeo786 wrote:Price of this kit?
Brackets R850.00 per set (incl 8.8 HT bolts)
Brake pads:
for street use ATE R181.00 per set
For the track EBC yellow R1091.00 per set
For a mix of track and steer EBC Green R907.00 per set
- yeo786
You have pm
Current :
VW Velociti 1.6i
Current :
VW Velociti 1.6i
- Car Model: Citi CTi 1.8i
hi there,
just a quick question, this would work on the Cti 's stock setup, not sure if they had the same caliper as all the rest?
also from the posts its seem 15" wheels a must? I'm still on the stock 14' s 6 spoke alloys
thanks
thanks
- Goldwagen Delarey
Will fit the the Cti stock calipers. Any you will have to get 15" rims. Caliper won't clear 14s
TX for the reply, this is something i am putting on the To Do list, together with the 15's
Hi there, another quick question, do you guys sell/stock the braided brake lines as well as the Dot 4+ fluid you (if I'm not mistaken) mentioned elsewhere and what are the prices?
TX
TX
- Goldwagen Delarey
We don't sell braided brake pipes but we do sell Motul RBF660 racing brake fluid. R174.00 per 500ml
Hi Viper,
Can you please give us a updated as to the prices?
- Goldwagen Delarey
Polo cup discs R900.00 per setKyli3boi wrote:Hi Viper,
Brake pads: R200.00 ferodo
Hi,
- Pieta
Hi bud,Kyli3boi wrote:Hi,
Send Viper a pm. He will get a notification if you pm him. He is not always on the forum.
I had the same kit on my car with no issues.
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
Online
Viper has this same kit on two of his personal vehicles and supplied dozens of other guys on the forum who are all happily driving them.
Should have taken it back before putting the grinder on it and explained your problem. The guys would have then been able to steer you right.Kyli3boi wrote:Hi,
