Please assist. I hav changed cam sensor so far... could it be fuel pump or airflow sensor?
Sent from my GT-I9060I using Tapatalk
Golf 5 cut out engine or loose power when excelerating
- SayedMK1
- Car Model: MK V GTi
Re: Golf 5 cut out engine or loose power when excelerating
Presss wrote:Please assist. I hav changed cam sensor so far... could it be fuel pump or airflow sensor?
Had a similar issue on my audi it was the high pressure fuel pump, i replaced it myself the little cap on the end (cam follower) gets worn out , if thats your issue hopefully you get it in time ,if not it wears through and causes damage on the cam lobe .
How did yr audi behaved on the road?isnt fuel pump in the tank ? Please advice im hopeless because we dignosid the car many times and fail to identify the problem source...it also gives a too low signal on the air intake sensor.we checked the voltage on the cables to the sensor and is low which relate to the machine reading. We performed that with a comparism from a perfect same engine.......
Howzit bru,
Check your LPFP,
Yes the one in the tank...
Check your LPFP,
- SayedMK1
[quote="Presss"]How did yr audi behaved on the road?isnt fuel pump in the tank ? Please advice im hopeless because we dignosid the car many times and fail to identify the problem source...it also gives a too low signal on the air intake sensor.we checked the voltage on the cables to the sensor and is low which relate to the machine reading. We performed that with a comparism from a perfect same engine.......
Sent from my GT-I9060I using Tapatalk[/quote
when you accelerate it had a flat spot then it took off . it also struggled on steep hills cutting out at times .
