Inferi Black Seat Leon Cupra - Detailed By Lawrence
- Lord of the Sponge
- Membership No: 1676
DazzG_177 and Mitch arrived at my place on Thursday evening to drop off DazzG_177's Inferi Black Seat (affectionately called Barney) for a full 3-day detail.
Products used:
Cyclo CM30
Turtle Wax Intensive Wheel Cleaner
Autofinesse Iron-Out
Chemical Guys Bare Bones
Chemical Guys Maxi Suds II
Meguiars Gold Class Shampoo
Autofinesse ObliTARate
Clay Magic (Blue) Clay
ONR
Meguiars Ultimate Compound
Meguiars Ultimate Polish
Lake Country Orange CCS Pads
Lake Country White CCS Pads
Lake Country Green Polishing Pads
Menzerna Black Finishing Pads
Chemical Guys Blacklight
Chemical Guys V7
Collinte 845
Meguiars NXT All Metal Polish
Smartwax Smart Dressing
C-Thru
A multitude of brushes and MF Cloths and foam applicator pads
HP Washer / Foam Cannon / Wet 'n Dry vac
Day 1 - Friday
Wheels, brake calipers and arches
The owner had these wheels refurbished recently however as you can see there is already a significant buildup of brake dust on them, and the calipers are in need of a full refurb, however a proper cleaning would suffice for now.
Here you can see the buildup of dirt in the arches (as well as the surface dirt on the car)
The wheels were removed from the car to reveal a fair amount of dirt, road grime, tar and iron deposits.
After a thorough cleaning of the wheels and tires all the tar spots were removed and the wheels treated to a full iron decontamination
Next the wheels arches
Before
After being cleaned
After Dressing
Each wheel was then sealed for protection before being put back on the car
Engine Bay
All loose dirt/dust was blown out the engine bay before the alternator and coilpacks were sealed off. A thoroughly cleaning was performed and the engine bay then dressed.
Before
After
Wash and decontamination
Before commencing with the wash I took a few pictures of damage to the paint, in the sun
As can be seen in this picture, the raised edges have taken some serious abuse over time (leaving minimal clear coat to work with)
The front end
Showing some damage to the front bumper
Surface dirt
Dirty door jambs
Dirty Exhaust
All the surface dirt was washed off and any previous protection stripped off the paint. In and around all the boot/door jambs, petrol cap, window seals, badges etc was then thoroughly cleaned. The car was then rinsed and dried in preparation for tar removal. Once the tar has been removed the entire car including the windows was subjected to a full iron decontamination. *** as a side note this was my first time using Autofinesse's Iron Out (I usually use Iron-x) and can say that it worked equally as well, if not better (it tended to foam a little more on agitation than the Iron-X - something I find very beneficial especially when cleaning wheels)***
After properly rinsing the car I set about claying the paintwork and glass surfaces. The amount of contamination was pretty 'normal' (this car is garaged at home and parked under cover during the day)
Day 2 - Saturday
Paint correction and refining
Now that all the 'gunk' sitting on top of the paint had been removed it was time to see what lurked below
And to start doing something about it (The target on this daily driver was certainly not a full correction and as such you will still notice the odd defect here and there - mainly deeper scratches etc) however a full 2 step correction was performed.
Before
After
Before
After
Before
During
After
50/50 showing rear door corrected / front not
Upon pulling the car out into the sun for an inspection I came across 2 very different colors
After discussing this with the owner it was established that some repair work had been done prior to him owning it and seemingly not all of what had been done was made known to him. It looks like the entire rear end up to the rear doors has been re-sprayed, and the colour match to the original color is somewhat off.
Day 3 - Sunday
Paint protection, Interior and final touches
The day started off with a final wash to remove any polishing dust which was then followed with the final 'polish' using Blacklight. I then sealed the paint using V7 and topped this with #845. The interior was vacuumed and exhaust tip polished. All glass surfaces were then cleaned and treated and all exterior plastic trim treated.
A shot of the Smart Dressing at work restoring the faded plastic trim
Onto the after shots! - I just love how the color changes from black to purple depending on the light....
And lastly the little white speck you see in the reflections of this shot
Was this flying overhead
Thanks for looking
Products used:
Cyclo CM30
ONR
Chemical Guys V7
Collinte 845
C-Thru
Day 1 - Friday
Before
After being cleaned
After Dressing
Engine Bay
Before
After
The front end
Surface dirt
Dirty door jambs
Dirty Exhaust
Day 2 - Saturday
Before
After
Before
After
Before
During
After
Day 3 - Sunday
Thanks for looking
- ree1
- Car Make: BMW
- Car Model: 2018 320D
Re: Inferi Black Seat Leon Cupra - Detailed By Lawrence
well done lawrence, dazz you must be very happy
[url=http://vwclub.co.za/forum/viewtopic.php ... 0#p1872034]
Ex dubs
12 Polo GTI DSG
11 Polo GTI DSG
06 Polo 1.9 Sportline
Ex dubs
12 Polo GTI DSG
11 Polo GTI DSG
- DarthJB
- Car Model: MK2 Jetta CSL
Daaaaaamn
Very nice
Very nice
- Belix
- Car Model: Passat B8
Must be rewarding to see all those hours paying off. Top work as usual!
- Car Make: SEAT
- Car Model: Leon Cupra
Dude you have no idearee1 wrote: well done lawrence, dazz you must be very happy
Completely happy with the work done
Car can finally start looking the part to match the power
Thanks again bud
Only a pleasure bud and glad you are chuffedDazzG_177 wrote:Dude you have no idearee1 wrote: well done lawrence, dazz you must be very happy
Thanks again bud
thanksDarthJB wrote:Daaaaaamn
Very nice
Thanks Marco - yeah it was a very rewarding color to work on!Belix wrote:Must be rewarding to see all those hours paying off. Top work as usual!
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
one of my favourite VAG colours and u really made it sparkle
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Good Gracious me
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
- Mshengulala
- Car Model: MK 6 GTI
Every Monday I patiently wait to see what Lawrence has been up to over the weekend and boy am I always impressed. Excellent yet again.
`12 CW MK6 GTI DSG-stock
`02 Polo Playa 1.8-stock
Thanks guys
You won't need to wait that long as I should be starting another car tomorrow morning. Being on leave FTWMshengulala wrote:Every Monday I patiently wait to see what Lawrence has been up to over the weekend and boy am I always impressed. Excellent yet again.
- Voora Molester
- Life-R
- Car Model: Polo
Wow that is impressive, well done Lawrence!
2014 Polo Bluemotion 1.2 TDi
OEM+
2007 Polo GTi 1.8T
Stealth Tuned/Powerflow DP/PD160+CAI/Forge 008 DV/Forge TIP/4Bar FPR/Seat Sport FMIC/JOM Coilovers
2004 Citi Life 1.6i
Unichip/Viper Branch/Powerflow Exhaust/K&N Filter
OEM+
2007 Polo GTi 1.8T
2004 Citi Life 1.6i
yakuza racer wrote:and i came.....
3 times already
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
Tiguan 2018 R-Line
Polo 6C Ex
Polo 2008(9n3)Ex:-(
- Colonel
- Car Model: Polo 1.0 R-Line
- Membership No: 1840
Awesome work as always lawrence. This paint is really amazing. All dark and forboding at night, and all pretty and purple in the sunlight.
2019 VW Polo Vivo GT 1.0TSI (Reef Blue Metallic)
2019 Toyota Rav-4 GX-R AWD (Graphite Grey Metallic)
2019 VW Polo 1.0 R-Line (Reef Blue Metallic)
2012 VW MKVI GTI (Candy White)
2011 VW Polo 6R Comfortline (Black Magic Pearl)
2008 Opel Corsa Lite+ (Silver)
1990 VW Fox 1.3 (Red)
- devZo
- Car Model: Polo TSI
- Membership No: 1395
Top Stuff , love the colour!
Polo TSI Highline DSG
ex:Polo TSI Comfortline
ex:MKVII GTI DSG
ex:MKVI GTI DSG CPi Tuned
ex:MKV GTI CPi Tuned
ex:Polo TDI Sportline
ex:VeloCiti 1.4i
Ex-Rides Thread
ex:MKVII GTI DSG
ex:VeloCiti 1.4i
Ex-Rides Thread
thanks for all the comments guys - really appreciate it!
- Voora Molester
bru when you gonna have a "detail day"??lawrence wrote:thanks for all the comments guys - really appreciate it!
where you show people how to do things right, a few people some drinks after etc... would pay for a good "DIY training day"
Thupercharged S4
- Post Wit Blitz
- Car Make: Seat
- Car Model: Ibiza Cupra
Yeah ! Nice Work Lawrence !
Seat Ibiza Cupra
- LavernG5
- Car Model: Golf 7R 2016
Nice work Lawrence, Damn this ride looks brand new Dazz.
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=117225
2016 Golf 7 R
2011 Golf 6 GTi ex
2009 Golf 5 GTi ex
- Car Make: SEAT
Thanks budLavernG5 wrote:Nice work Lawrence, Damn this ride looks brand new Dazz.
Enjoy driving the car even more now
I still have more plans in store for this project
- Lambchop
WOW !!!!
Well done Lawrence
Well done Lawrence
thanks bud
Sent from my GT-I9300 using Tapatalk 2
- Car Model: Corrado
- PöLö1.4...
- Car Model: Polo Playa
Absolutely awesome awesome work Lawrence !!
Wish you were in JHB so you could detail my car!!
Car looks Epic now DazzG!
