mk1 coil wiring diagram
- Car Model: Mk2 Gti 8v
Does anyone have one for me please?
BMW E30 325i
Jetta 6 1.4 TSI
Ex-MK2 Gti 1988 1800, 8v OEM
Ex-MK1 Gti 1985 , CTI injection.
Ex-MK3 Vr6 97exec(standard).
Ex-VFR 400(NC30) 1992, aftermarket Can.
Ex-MK1 2door- 1800 8v, 4-1 branch,powerflow 50mm(RIP)
Ex-1990 Mk2 CSL Jetta aka VR1(Sold)
Ex-1987 Toyota Corolla 1.6GL slantfront(stolen)
Rides thread : http://www.vwclub.co.za/forum/viewtopic ... 4#p2505684
Jetta 6 1.4 TSI
Re: mk1 coil wiring diagram
Uhm a coil is pretty simple. One side is + form the ignition and the otherside is - from either the tp100 or the points depending on how old the mk1 is.
panic-mechanic wrote:Uhm a coil is pretty simple. One side is + form the ignition and the otherside is - from either the tp100 or the points depending on how old the mk1 is.
Its an 85 gti so has a TCI unit.
My coil has 2 wires going to each side of it.
Not all coil wire colour codes are the same either.
So this might be simple to you but without wiring diagram or pic, a noob like me will struggle a bit.
I think we need an electrics section>Dont you think?
BMW E30 325i
Jetta 6 1.4 TSI
Jetta 6 1.4 TSI
Ok the 2 wires on the + side is a power from the ignition and the other goes to the tci to power it.
On the negative there is a green wire which is the signal form the tci and the othr is a red with black trace which goes to the cluster and is the rev countr signal.
Thanks.Will the car start up if the coil wires are swapped around?panic-mechanic wrote:Ok the 2 wires on the + side is a power from the ignition and the other goes to the tci to power it.
BMW E30 325i
Jetta 6 1.4 TSI
Jetta 6 1.4 TSI
It might but the spark will be weak. Just check it they are usually clearly marked and the black wires must be on the side marked +
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Mate of mine had a problem where his motor sounded like it wanted to start but didn't, we suspected fuel but it turned out the TP100 was causing weak spark, swapped in a new one - problem sorted.panic-mechanic wrote:It might but the spark will be weak. Just check it they are usually clearly marked and the black wires must be on the side marked +
Current rides:
Hyundai - 1.4 Getz (daily)
Fankspanic-mechanic wrote:It might but the spark will be weak. Just check it they are usually clearly marked and the black wires must be on the side marked +
BMW E30 325i
Jetta 6 1.4 TSI
Jetta 6 1.4 TSI
- 16V Dub
- Car Model: GOLF 1
Hi...
If you still having issues, go to Goldwagen and buy an ignition harness/loom for R79. Plug it to distributor, module and coil.
Thereafter test with test light and see which existing wire on car has power when you put key, that wire goes on positive of coil.
I did that last week on my car. Started on the turn.
Daily Ride / Tow Vehicle : Citi Golf, 2.0lt 16V, Auto...
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=131489
Drag Car : 2.0lt 16valve Golf 1
The car is fine teamog.Thanks.Just wanted to know about the wiring.I found what i needed or something close check :TEAMOG wrote:Hi...
BMW E30 325i
Jetta 6 1.4 TSI
Jetta 6 1.4 TSI
How to wire vw Jetta 3 clx module to coil harness it will assist if I can get reply with pics
