Morning guys.
So the weekend has come n gone, yesterday I started my gf car, velociti, and could hear the motor rev up through all the speakers, after a while it went away. This morning on her way to work she says the interference happened again and the radio went completely dead. After she gave it a PK it worked again with no interference.
Any suggestions before I strip it out tonight to see what's happening, thanks guys.
Intermittent interference
- Car Make: Toyota
- Car Model: Tazz
- Car Make: Toyota
- Car Model: Tazz
Re: Intermittent interference
I suspect a faulty ground connection. Would that be battery and amp? Any other place?
- dcmk4
- Registered for: 10 years
- Car Model: MK7 GTi
If it works then starts causing trouble again it must be forgetting about the pk it received. Maybe it needs a harder pk.
- Car Make: Toyota
- Car Model: Tazz
Day is made
Toss the head unit in the bin. Or send it in for repairs.
PK solution means it has faulty connections.
- Car Make: Toyota
- Car Model: Tazz
It's pretty brand new head unit. Maybe a year old. The wiring got redone ,had a few issues after that with loose connections on the amp and then the fuse popped. Got a new fuse and all was well until the other day. So far it has behaved, Will be having a look this weekend, just to check all the connections and wires. Will post what I find
- EX-DOHCTOR
- Membership No: 712
Makes sure the amp ground point is direct on to metal.
- Car Make: Toyota
- Car Model: Tazz
Thanks for the advice. Will sand the terminal and the body to make sure of the contact.
- Wheel Whore
Try a alternator suppressor. It worked on my polo.
