Hi my name is Gavin and i own a VW CADDY Maxi 2litre TDI..Its a 2011Model with a CLC Motor..
I have been having endless problems with my van losing brakes .. I have to constantly bleed the brakes every day before i drive it
each day becuase by the end of the day the brakes are flat again. it seems there is air in the system and we have replaced the
Master Cylinder with a secondhand one twice and and we still have this problem.. 2 of them surely cant have the same symptom...
Im really hoping someone can advise me as im really tired of bleeding brakes everyday..
If anyone knows of a place that can refurbish or supply a aftermarket cylinder in the Durban area...
If someone can advise us on where air could be getting into the system..
PLEASE HELP...
Losing Brakes all the time
- ICE King
Re: Losing Brakes all the time
Hi and Welcome to the forum.
I recall coming across this before, Sounds like there is air in the ABS pump -Will need VCDS to bleed the abs pump.
Also try to bleed as follows: Front Left then Front Right then rear Left then rear right, best while ABS pump is running.
- Neuk
- Treasurer
- Membership No: 806
Why bleed that way? I have always bleed the furthest wheel first, so back right if you are looking at the car, in my MkI's case.ICE King wrote:Also try to bleed as follows: Front Left then Front Right then rear Left then rear right, best while ABS pump is running.
- ICE King
Since all the lines run to the ABS pump(located front left) then a single line runs across to the MC.(where as pre ABS , it all ran to the MC)Neuk wrote:Why bleed that way? I have always bleed the furthest wheel first, so back right if you are looking at the car, in my MkI's case.ICE King wrote:Also try to bleed as follows: Front Left then Front Right then rear Left then rear right, best while ABS pump is running.
The whole idea is to get the air out the ABS pump and can only be activated by either a scan tool or by driving fast and standing on the brakes letting the ABS kick in.
I agree that on a non ABS car the traditional way, furthest then work your way closest to the MC.
The procedure needs to be done 100%, otherwise start over if air gets in again.
- Neuk
- Treasurer
Cool, the ABS pump puts a kink in the pipework, so to speak.ICE King wrote:Since all the lines run to the ABS pump(located front left) then a single line runs across to the MC.(where as pre ABS , it all ran to the MC)Neuk wrote:Why bleed that way? I have always bleed the furthest wheel first, so back right if you are looking at the car, in my MkI's case.ICE King wrote:Also try to bleed as follows: Front Left then Front Right then rear Left then rear right, best while ABS pump is running.
The whole idea is to get the air out the ABS pump and can only be activated by either a scan tool and by driving fast and standing on the brakes letting the ABS kick in.
- ICE King
It does and is ..itch if you don't have the right tools.Neuk wrote:Cool, the ABS pump puts a kink in the pipework, so to speak.ICE King wrote:Since all the lines run to the ABS pump(located front left) then a single line runs across to the MC.(where as pre ABS , it all ran to the MC)Neuk wrote:Why bleed that way? I have always bleed the furthest wheel first, so back right if you are looking at the car, in my MkI's case.ICE King wrote:Also try to bleed as follows: Front Left then Front Right then rear Left then rear right, best while ABS pump is running.
- DieterMK5
- Car Model: Jetta MK5 1.9 TDi
- Membership No: 3015
Hello and welcome to the VW Club Forum!
We all hope that you enjoy your stay here and consider the wonderful opportunity of becoming a VWCSA Member and get awesome vwclub merchandise for only R300.
Before you do, please have a look at the Forum Rules
As well as the rules we have for Private Sales
If you have any questions pertaining to your vehicle and not to do with introducing yourself, post them in the Technical Discussions section
Please feel free to join in on the Events, its huge fun, and non-members are also more than welcome to join in on the action. Hope to see you at an event soon.
Now that you have introduced yourself to the forum, have a look at starting a Rides Thread and show us what you cruise the streets with.
(How to Post a Picture)
We look forward to having you on the forum, and hope to see you grow in the club, by becoming a member, and most of all, making new friends.
Cheers
Cheers
- Reegz
- Membership No: 1400
Hello and welcome to the forum!
2016 Golf 7 Tyre Devourer
---- Ex ----
2008 Honda CBR 600RR - SOLD
1996 Citi Golf CTi - SOLD
---- Ex ----
